    M5Unified FreeRTOS (ESP-IDF) Application not Compiling
    2 Posts 1 Posters 755 Views
    • N Offline
      NevynUK
      I am attempting to create a new ESP-IDF application that will use FreeRTOS application (so not Arduino). I am getting build errors and I was wondering if anyone has managed to get this working.
      So I did the following:
      idf.py create-project M5Test
      idf.py set-target esp32p4
      idf.py add-dependency "m5stack/m5unified^0.1.16"
      idf.py build
      I see the managed components (M5Unifed and M5GFX) caaded to the managed_components directory as expected.
      However I see build errors in the M5GFX component.
      ESP-IDF: 5.5
      Target platform: Tab5
      Thanks in advance,
      Mark
      • N Offline
        NevynUK @NevynUK
        I finally managed to get an application working with graphics and touch on the Tab5. My solution:
        • Removed any reference to managed components in the idf_component.yml files.
        • Clone the M5Unified and M5GFX repositories and put them in the components directory.
        • Added references to CMakeLists.txt for the added components.
        Application now builds and I have tested the display with the BarGraph anf the TouchTest applications.
        Hope this helps anyone experiencing the same issue.
        Regards,
        Mark
