    M5Apps - multiple apps installer
    18 Posts 9 Posters 17.0k Views
      d4rkmen @erwantest123
      @erwantest123 was my fault. I have put single app file to M5Burner isntead of full fw :(
      Check for new TOP-20 updates:
      • Snake: classic game
      • M5Tuna: guitar tuner app
      Both apps are ~350Kb, could be used with M5Apps very well
        d4rkmen
        v1.5
        • Added version to boot animation
        • Cloud source error messages are now more informative
        • Minor UI fixes (hints, navigation, sound)
        • B Offline
          bigchease
          this might be a dumb question but is there any way to get a bin file for m5 launcher
            d4rkmen @bigchease
            @bigchease no, you have to flash full firmware (bootloader, PT, nvs, and the rest). Thans why you have to use some other flasher like M5Burner or esptools.
              kermit17 @d4rkmen
              @d4rkmen
              Hi, are you talking about M5 Launcher project or something different?
              I'm confused (new user) as the version numbers seem very different between what you say and what I see on M5 Burner.
              PS is there any chance of something like this for Tab5?
              • ImLunchtimeI Offline
                ImLunchtime
                Would this project ever be open-source? I was trying to create such a firmware manager for my Tab5 device and was encountering troubles, the M5Launcher's approach was strange (seems like it needs a custom bootloader which I don't have) so I wanted to check M5Apps out. It would be the best if M5Apps are open source.
                • Y Offline
                  yehors
                  If this broke your cardputer here is how to fix it:
                  Before plugging your cardputer in hold the GO button and then plug in the cable. Cardputer will enter the download mode and you can then flash everything you want!
                  ~ yehor
                    troyler
                    is there a way to increase the storage to add more apps, i have 64gb.
                      d4rkmen
                      New version available on M5Burner
                      v1.9
                      • Added new app FINDER: two-panel file manager for SD card and USB drive
                      • Improved keyboard navigation in all apps
                      • Fixed keyboard sound issues
                      • INSTALLER: Added sorting files and folders by name
                      • INSTALLER: Cloud source fixed HTTP buffers
                      • FDISK: Added creation of new data partitions (press A)
                      • FDISK: No reboot required after deleting data partition
                      • Updated to the latest ESP-IDF v5.5.1
                      • Updated USB MSC driver
                        dzepetko
                        How can i install meshtastic and 4exampe winamp? - i have error not enough space.. ;/
                          cricri
                          Nice job !!! very interesting approch with no burning in between apps
                          But memory is a real limit
                          How to uninstall unused app from memory ?
                            d4rkmen @cricri
                            @cricri There is FDISK utility built-in.
                            You can list all the partitions and delete those are not used anymore. System partitions are read-only, so you will not delete anything extra.
                            Also you can create new partition at any time. For example, the Game Station requires spare partition for cache. so just add it in FDISK with a few clicks.
                            @dzepetko said in M5Apps - multiple apps installer:
                            By default the SDK (ESP-IDF) makes firmware bundle with default partitions, But the thing is: application could not use it at all or use one of them. So we can cook a binary with only partitions that really need by the app. This can save much space.
