    M5Apps - multiple apps installer
    18 Posts 9 Posters 19.0k Views
      d4rkmen
      v1.5
      • Added version to boot animation
      • Cloud source error messages are now more informative
      • Minor UI fixes (hints, navigation, sound)
      • B Offline
        bigchease
        this might be a dumb question but is there any way to get a bin file for m5 launcher
          d4rkmen @bigchease
          @bigchease no, you have to flash full firmware (bootloader, PT, nvs, and the rest). Thans why you have to use some other flasher like M5Burner or esptools.
            kermit17 @d4rkmen
            @d4rkmen
            Hi, are you talking about M5 Launcher project or something different?
            I'm confused (new user) as the version numbers seem very different between what you say and what I see on M5 Burner.
            PS is there any chance of something like this for Tab5?
            • ImLunchtimeI Offline
              ImLunchtime
              Would this project ever be open-source? I was trying to create such a firmware manager for my Tab5 device and was encountering troubles, the M5Launcher's approach was strange (seems like it needs a custom bootloader which I don't have) so I wanted to check M5Apps out. It would be the best if M5Apps are open source.
              • Y Offline
                yehors
                If this broke your cardputer here is how to fix it:
                Before plugging your cardputer in hold the GO button and then plug in the cable. Cardputer will enter the download mode and you can then flash everything you want!
                ~ yehor
                  troyler
                  is there a way to increase the storage to add more apps, i have 64gb.
                    d4rkmen
                    New version available on M5Burner
                    v1.9
                    • Added new app FINDER: two-panel file manager for SD card and USB drive
                    • Improved keyboard navigation in all apps
                    • Fixed keyboard sound issues
                    • INSTALLER: Added sorting files and folders by name
                    • INSTALLER: Cloud source fixed HTTP buffers
                    • FDISK: Added creation of new data partitions (press A)
                    • FDISK: No reboot required after deleting data partition
                    • Updated to the latest ESP-IDF v5.5.1
                    • Updated USB MSC driver
                      dzepetko
                      How can i install meshtastic and 4exampe winamp? - i have error not enough space.. ;/
                        cricri
                        Nice job !!! very interesting approch with no burning in between apps
                        But memory is a real limit
                        How to uninstall unused app from memory ?
                          d4rkmen @cricri
                          @cricri There is FDISK utility built-in.
                          You can list all the partitions and delete those are not used anymore. System partitions are read-only, so you will not delete anything extra.
                          Also you can create new partition at any time. For example, the Game Station requires spare partition for cache. so just add it in FDISK with a few clicks.
                          @dzepetko said in M5Apps - multiple apps installer:
                          By default the SDK (ESP-IDF) makes firmware bundle with default partitions, But the thing is: application could not use it at all or use one of them. So we can cook a binary with only partitions that really need by the app. This can save much space.
