    Internal pull-up support on Unit PbHub / Unit EXT.IO2?
    3 Posts 2 Posters 2.0k Views
      sk-ys
      I am using Unit PbHub and would like to ask about internal pull-up resistors.
      The STM32F030 used in PbHub and EXT.IO2 supports internal pull-up/pull-down at the hardware level, but I could not find any way to enable pull-ups using the current M5Stack libraries. There seems to be no API to configure pull modes.
      Is it currently possible to enable internal pull-up resistors on PbHub or EXT.IO2?
      If not, is firmware modification the only option, or are there plans to support this in the future?
      I would appreciate any official clarification or recommended workaround.
      Thank you.
      • felmueF Online
        felmue @sk-ys
        Hello @sk-ys
        currently PbHub does not support internal pull-up/pull-down resistors. See FAQ at the end of the documentation page here. I assume the same is true for EXT.IO2.
        Note: I have no idea if there are plans to support this feature in the future.
        BTW: I faced the same issue a while ago and I resorted to adding some 10 k SMD resistors to the inputs.
          sk-ys @felmue
          Thank you for the clarification.
          Yes, it seems that internal pull-up/pull-down resistors cannot be controlled at the moment.
          I also checked the documentation, but could not find any way to configure this, which is why I posted the question here.
          I hope this feature can be supported in the future, as it would be very useful in practice.
          Thanks again for sharing your experience.
