    External Power - What is possible?
    15 Posts 6 Posters 44.5k Views 3 Watching
      moelski @world101
      @world101 在 External Power - What is possible? 中说:
      m5stack battery module. 850mAh of internal power. If you need more than that, it will have to be custom.
      Hi !
      I know there is a battery pack and I got two of them. But this is not always a solution. There are projects where you can't stack a lot of moduls on top of each other. And as said ... Using USB as power is very ugly and space consuming.
      Correct. And what I want to know is which custom solutions are available.
      Or to be more precise ... Which kind of power solutions are available without using the Battery module or an USB connection and which kind of drawbacks have those solutions?
      I can't beleave that I'm the only guy how has those "problems".
      regards
      Dominik
      • loborisL Offline
        loboris
        M5Stack power circuit is designed in a way that you can use only a Li-Po battery (other than USB power) as external power source.
        For all other solutions you have to modify the PCB.
        If you look at the schematic you can see that the external 5V source could be added at several places, but in all cases you have to cut some PCB traces.
        The simplest method should be to attach the external 5V to VIN_USB, no trace cutting is needed, but you should not connect USB cable at the same time the external 5V is connected.
        • loborisL Offline
          loboris @moelski
          @moelski 在 External Power - What is possible? 中说:
          It looks very ugly to use a USB Connector
          If you use external power, some kind of connector must be used.
          You could use USB cable with right angle connector, like this one, I don't think it looks ugly.
          You can remove the USB-A connector on the other side, and attach whatever power source you have.
          cable
            moelski
            cutting traces on the PCB is always a bad idea I think ...
            But connecting a 5V source to the 5V connection on the 2x15 connector should be ok, or not? If there is no battery connected we don need the IP5306?
            That's correct but this is a compromise I can live with.
            regards Dominik
            • loborisL Offline
              loboris @moelski
              5V connection on the 2x15 connector is the output from IP5306 VOUT pin (5V Boost output pin), so I don't think it is wise to connect external 5V to it.
                moelski
                @loboris 在 External Power - What is possible? 中说:
                Well if there is no battery connected and no USB cable attached ... Why should this be a problem?
                I would assume that the IP5306 has an internal protection for reverse current.
                  You are aware that there are 2 battery connection on the M5?
                  1 is in the 2x15 connection, one is on the actual main pcb.
                    moelski
                    @ajb2k3 在 External Power - What is possible? 中说:
                    Yes I saw that. I think that both directly connected to the VBat connection, correct?!
                    • loborisL Offline
                      loboris @moelski
                      It is not specified in the IP5306 datasheet.
                      You can test it and report the results.
                      • B Offline
                        b1063n
                        So, did anyone find a solution. I was about to buy it, but then when I look at the documentation for the power supply voltage I cannot find it! Documentation is quite poor I must add.
                        I do not need battery operated solution, and the USB power is super ugly and inconvenient!
                        I need to use external 5V power supply connected to pins inside the board in a professional manner (no pcb hacking). Is this not possible? I cannot believe it!!
                          ajb2k3 @b1063n
                          @b1063n said in External Power - What is possible?:
                          Yes it is possible as the Stackable modules provide internal power to M5Stack cores. (Sorry been working on my books and documenting units with demos this weekend.)
                          The documents I have, show that each stackable module has its own voltage regulator that delivers 5 volts to pin 28 of the internal bus (+5V).
                          If you look at the Proto module you will see that these pins are marked ready for you.
                          https://docs.m5stack.com/#/en/module/proto
