    69 Posts 7 Posters 436.3k Views 1 Watching
    • G Offline
      GACHAPO
      Hello - I've downloaded before but I don't think it has .ino files so can't be used with Arduino.ide. Please advise?
        ajb2k3 @GACHAPO
        @gachapo said in [Solved] M5 Burner Firmware Option Update:
        No, the driver is compiled with the espressiv IDF and so you need to install that and configure it to compile.
        Something I have failed to do several times now.
        • m5-docsM Offline
          m5-docs
          can also program with arduino ide
          https://github.com/m5stack/Applications-cam
          M5Stack documentation URL
          https://docs.m5stack.com
          • G Offline
            GACHAPO @m5-docs
            @watson Ok - so frustrated was I with my first attempt I purchased a M5Camera ESP32 PSRAM. Works out of the box nicely, but only on it's own wifi (192.168.4.1). However, as previously I need to get onto my network.
            Therefore, using Arduino IDE I have gone to File, Examples, ESP32, Camera nd loaded up the sketch from there.
            I have then amended the SSID and Password to my own and defined the PSRAM camera as below;
            Compiles and uploaded the sketch.
            Nothing! - Camera doesn't even turn on.
            Can somebody please, simply tell me where I am going wrong and how you ever get this great product on your own network.
            • O Offline
              Oyye @GACHAPO
              @gachapo
              I just registered for you :D
              Here what is solved my problem (Y2_GPIO_NUM):
              #elif defined(CAMERA_MODEL_M5STACK_PSRAM)
              #define PWDN_GPIO_NUM -1
              #define RESET_GPIO_NUM 15
              #define XCLK_GPIO_NUM 27
              #define SIOD_GPIO_NUM 25
              #define SIOC_GPIO_NUM 23
              #define Y9_GPIO_NUM 19
              #define Y8_GPIO_NUM 36
              #define Y7_GPIO_NUM 18
              #define Y6_GPIO_NUM 39
              #define Y5_GPIO_NUM 5
              #define Y4_GPIO_NUM 34
              #define Y3_GPIO_NUM 35
              #define Y2_GPIO_NUM 17 //32
              #define VSYNC_GPIO_NUM 22
              #define HREF_GPIO_NUM 26
              #define PCLK_GPIO_NUM 21
              ajb2k3A G 2 Replies Last reply Reply Quote 0
                ajb2k3 @Oyye
                @oyye said in [Solved] M5 Burner Firmware Option Update:
                @gachapo
                Welcome to the forum!
                • G Offline
                  GACHAPO @Oyye
                  @oyye Thank-you,
                  I did as you stated with only change from the Arduino Examples being;
                  This has made no change - Camera still does not come on.
                  Just to be absolutely clear - this is the camera a have
                  ![0_1556260445735_20190426_073011.jpg](Uploading 100%)
                  • G Offline
                    GACHAPO
                    Is anybody able to help me please? I now have 2 cameras and I am completely unable to get them on my wifi network as intended. Thank you
                    • m5-docsM Offline
                      m5-docs @GACHAPO
                      @gachapo Do you own M5Camera A model and B model? or ESP32CAM?
                      • G Offline
                        GACHAPO @m5-docs
                        @m5-docs I own an M5 OV2640 ESP32PSRAM Camera
                        • m5-docsM Offline
                          m5-docs @GACHAPO
                          @gachapo But, M5Camera A model and B model both own PSRAM chip.
                          Please take a picture for your camera board.
                          https://docs.m5stack.com/#/en/unit/m5camera
                          • G Offline
                            GACHAPO
                            Mine is B
                            • m5-docsM Offline
                              m5-docs @GACHAPO
                              Hello @gachapo
                              You can download the following example code for your board.
                              That's the configuration for B Model.
                              #define SIOD_GPIO_NUM     22
                              #define Y2_GPIO_NUM       32
                              #define VSYNC_GPIO_NUM    25
                              • G Offline
                                GACHAPO
                                I feel like I'm walking through mud!!!!!!!!!!!!!!!!!!
                                I have downloaded the software as suggested.
                                I amended the SSID and Password to enable access to my network
                                I compile and uploaded the software
                                Surprisingly a new access point LidarBot + MAC address appeared, contrary to me setting my own network credentials.
                                I connected to this AP and put the password in as stated in the code.
                                browsed to 192.168.4.1
                                Software appeared, but no camera image and NO ABILITY TO GET ON MY NETWORK, WHICH IS WHAT I HAVE REQUESTED AGAIN AND AGAIN.
                                It doesn't have to be this hard.........................................................please make it simple!
                                How do I get this camera on my network with Arduino IDE????
                                • m5-docsM Offline
                                  m5-docs @GACHAPO
                                  @gachapo What log information did your device print?
                                  • G Offline
                                    GACHAPO
                                    • G Offline
                                      GACHAPO
                                      • G Offline
                                        GACHAPO
                                        I fail to see how all this gets me connected to my network???
                                        Do we have a solution or not?
                                        • G Offline
                                          GACHAPO @GACHAPO
                                          @gachapo 5 Months on I STILL would like to use my M5 Stack ESP32 PSRAM camera on my network.
                                          Is it at all possible to do this yet?
                                          V 1 Reply Last reply Reply Quote 0
                                          • V Offline
                                            vany5921 @GACHAPO
                                            @gachapo
                                            try this
                                            https://github.com/m5stack/m5stack-cam-psram/tree/master/wifi
                                            use esp-idf or esptool to burn it
