    69 Posts 7 Posters 428.5k Views 1 Watching
      ajb2k3 @Oyye
      @oyye said in [Solved] M5 Burner Firmware Option Update:
      @gachapo
      I just registered for you :D
      Here what is solved my problem (Y2_GPIO_NUM):
      #elif defined(CAMERA_MODEL_M5STACK_PSRAM)
      #define PWDN_GPIO_NUM -1
      #define RESET_GPIO_NUM 15
      #define XCLK_GPIO_NUM 27
      #define SIOD_GPIO_NUM 25
      #define SIOC_GPIO_NUM 23
      #define Y9_GPIO_NUM 19
      #define Y8_GPIO_NUM 36
      #define Y7_GPIO_NUM 18
      #define Y6_GPIO_NUM 39
      #define Y5_GPIO_NUM 5
      #define Y4_GPIO_NUM 34
      #define Y3_GPIO_NUM 35
      #define Y2_GPIO_NUM 17 //32
      #define VSYNC_GPIO_NUM 22
      #define HREF_GPIO_NUM 26
      #define PCLK_GPIO_NUM 21
      Welcome to the forum!
      • G Offline
        GACHAPO @Oyye
        @oyye Thank-you,
        I did as you stated with only change from the Arduino Examples being;
        This has made no change - Camera still does not come on.
        Just to be absolutely clear - this is the camera a have
        ![0_1556260445735_20190426_073011.jpg](Uploading 100%)
        • G Offline
          GACHAPO
          Is anybody able to help me please? I now have 2 cameras and I am completely unable to get them on my wifi network as intended. Thank you
          • m5-docsM Offline
            m5-docs @GACHAPO
            @gachapo Do you own M5Camera A model and B model? or ESP32CAM?
            M5Stack documentation URL
            https://docs.m5stack.com
            • G Offline
              GACHAPO @m5-docs
              @m5-docs I own an M5 OV2640 ESP32PSRAM Camera
              • m5-docsM Offline
                m5-docs @GACHAPO
                @gachapo But, M5Camera A model and B model both own PSRAM chip.
                Please take a picture for your camera board.
                https://docs.m5stack.com/#/en/unit/m5camera
                • G Offline
                  GACHAPO
                  Mine is B
                  • m5-docsM Offline
                    m5-docs @GACHAPO
                    Hello @gachapo
                    You can download the following example code for your board.
                    https://github.com/m5stack/Applications-cam
                    That's the configuration for B Model.
                    #define SIOD_GPIO_NUM     22
                    #define Y2_GPIO_NUM       32
                    #define VSYNC_GPIO_NUM    25
                    • G Offline
                      GACHAPO
                      I feel like I'm walking through mud!!!!!!!!!!!!!!!!!!
                      I have downloaded the software as suggested.
                      I amended the SSID and Password to enable access to my network
                      I compile and uploaded the software
                      Surprisingly a new access point LidarBot + MAC address appeared, contrary to me setting my own network credentials.
                      I connected to this AP and put the password in as stated in the code.
                      browsed to 192.168.4.1
                      Software appeared, but no camera image and NO ABILITY TO GET ON MY NETWORK, WHICH IS WHAT I HAVE REQUESTED AGAIN AND AGAIN.
                      It doesn't have to be this hard.........................................................please make it simple!
                      How do I get this camera on my network with Arduino IDE????
                      • m5-docsM Offline
                        m5-docs @GACHAPO
                        @gachapo What log information did your device print?
                        • G Offline
                          GACHAPO
                          • G Offline
                            GACHAPO
                            • G Offline
                              GACHAPO
                              I fail to see how all this gets me connected to my network???
                              Do we have a solution or not?
                              • G Offline
                                GACHAPO @GACHAPO
                                @gachapo 5 Months on I STILL would like to use my M5 Stack ESP32 PSRAM camera on my network.
                                Is it at all possible to do this yet?
                                V 1 Reply Last reply Reply Quote 0
                                • V Offline
                                  vany5921 @GACHAPO
                                  @gachapo
                                  try this
                                  https://github.com/m5stack/m5stack-cam-psram/tree/master/wifi
                                  use esp-idf or esptool to burn it
                                  • G Offline
                                    GACHAPO @vany5921
                                    @vany5921
                                    For those who would like to keep their sanity i have FINALLY managed to do this, my God it's been a journey.
                                    I followed this wonderful website;
                                    https://www.mgo-tec.com/blog-entry-m5camera-arduino.html/3
                                    I basically changed the following pins
                                    ● Line 41: (#define SIOD_GPIO_NUM)
                                    Changed to 22
                                    ● Line 52: (define VSYNC_GPIO_NUM)
                                    Changed to 25
                                    I now have the camera on my network!!
                                      JohnA @GACHAPO
                                      @gachapo Thanks for persevering with this as I got my M5 to day and was getting confused lol. Without this link I would never have got it up and running so thanks for the link as that has kept me from throwing it out of the window.
