    Can microSD card be accessed in UIFlow or with MicroPython?
    12 Posts 4 Posters 36.0k Views 1 Watching
    • Z Offline
      zhufu86
      I can not find any instruction in the documentation regarding how to access the tf card with python.
      Can anyone help me?
        Take a look at the micro python official forums, there is a discussion about it
        Micropython.org
        • lukasmaximusL Offline
          Not possible in uiflow yet. Micropython is easy
          import os
          os.mountsd()
          os.listdir('/sd')
          etc...
          Z 1 Reply Last reply Reply Quote 0
          • Z Offline
            zhufu86 @lukasmaximus
            @lukasmaximus
            thank you for your reply.
            But when I tried to exec os.mountsd I got an error as below.
            os.mountsd()
            W (20141) sdspi_host: spi bus changed (1 -> 2)
            E (20141) sdspi_host: spi bus 2 not available
            E (20141) vfs_native: Failed to initialize SDcard (258).
            OSError: [Errno 5] EIO
              ajb2k3 @zhufu86
              @zhufu86 said in Can TF card be accessed in UIFlow or with MicroPython?:
              @lukasmaximus
              os.mountsd()
              Can you post all you code please
              • Z Offline
                zhufu86 @ajb2k3
                I just exec in REPL.
                import os
                os.mountsd()
                nothing else....
                I also tried os.SDMODE_4LINE, os.SDMODE_1LINE and os.SDMODE_SPI with os.sdconfig(...) before mountsd(), but none of them worked.
                Forgot to say, I'm using M5Stack Fire.
                  ajb2k3 @zhufu86
                  import os
                  os.mountsd()
                  nothing else....
                  You also need the machine, sdcard and dpi library imported. That’s why I recommend that you visit MicroPython.org
                  • Z Offline
                    zhufu86 @ajb2k3
                    thank you.
                    I went to MicroPython.org but found nothing helpful.
                    Finally, I erased the firmware and burned the M5S with the UIFlow-v1.3.1-Beta firmware.
                    It worked, with the code below.
                    >>> import uos
                    >>> uos.sdconfig(uos.SDMODE_SPI,clk=18,mosi=23,miso=19,cs=4)
                    I (53596) gpio: GPIO[23]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pull             down: 0| Intr:0
                    I (53596) gpio: GPIO[19]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pull             down: 0| Intr:0
                    I (53604) gpio: GPIO[18]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pull             down: 0| Intr:0
                    >>> uos.mountsd()
                    W (65959) sdspi_host: spi bus changed (1 -> 2)
                    I (65959) gpio: GPIO[4]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulld             own: 0| Intr:0
                     Mode: SPI
                         Type: SDHC/SDXC
                        Speed: default speed (25 MHz)
                    SPI speed: 40 MHz
                          CSD: ver=1, sector_size=512, capacity=15523840 read_bl_len=9
                          SCR: sd_spec=2, bus_width=5
                    • Z Offline
                      zhufu86
                      Funny...
                      I re-burned back to UIFlow-v1.2.3, and it also worked.
                      >>> import uos
                      >>> uos.mountsd()
                      W (104277) sdspi_host: spi bus changed (1 -> 2)
                       Mode: SPI
                           Type: SDHC/SDXC
                      SPI speed: 20 MHz
                      • Z Offline
                        zhufu86
                        Here I attach the webpages which helps me mostly.
                        Hope it can help other people.
                        https://github.com/loboris/MicroPython_ESP32_psRAM_LoBo/wiki/filesystems
                        https://forum.micropython.org/viewtopic.php?t=4551
                        https://loboris.eu/forum/showthread.php?tid=85
                        Z 1 Reply Last reply Reply Quote 1
                        • Z Offline
                          zhufu86 @zhufu86
                          ok......
                          now even one simple uos.mountsd() also works...
                          good...
                          >>> import uos
                          >>> uos.mountsd()
                          W (497494) sdspi_host: spi bus changed (1 -> 2)
                           Mode: SPI
                               Type: SDHC/SDXC
                          SPI speed: 20 MHz
                            hema41
                            Yes, microSD cards can be accessed in UIFlow or with MicroPython. They allow you to read and write data from/to the microSD card, enabling storage and retrieval of information on compatible devices.
