    Can microSD card be accessed in UIFlow or with MicroPython?
    12 Posts 4 Posters 36.0k Views 1 Watching
      Take a look at the micro python official forums, there is a discussion about it
      Micropython.org
      • lukasmaximusL Offline
        Not possible in uiflow yet. Micropython is easy
        import os
        os.mountsd()
        os.listdir('/sd')
        etc...
        Z 1 Reply Last reply Reply Quote 0
        • Z Offline
          zhufu86 @lukasmaximus
          @lukasmaximus
          thank you for your reply.
          But when I tried to exec os.mountsd I got an error as below.
          os.mountsd()
          W (20141) sdspi_host: spi bus changed (1 -> 2)
          E (20141) sdspi_host: spi bus 2 not available
          E (20141) vfs_native: Failed to initialize SDcard (258).
          OSError: [Errno 5] EIO
            ajb2k3 @zhufu86
            @zhufu86 said in Can TF card be accessed in UIFlow or with MicroPython?:
            @lukasmaximus
            os.mountsd()
            Can you post all you code please
            • Z Offline
              zhufu86 @ajb2k3
              I just exec in REPL.
              import os
              os.mountsd()
              nothing else....
              I also tried os.SDMODE_4LINE, os.SDMODE_1LINE and os.SDMODE_SPI with os.sdconfig(...) before mountsd(), but none of them worked.
              Forgot to say, I'm using M5Stack Fire.
                ajb2k3 @zhufu86
                import os
                os.mountsd()
                nothing else....
                You also need the machine, sdcard and dpi library imported. That’s why I recommend that you visit MicroPython.org
                • Z Offline
                  zhufu86 @ajb2k3
                  thank you.
                  I went to MicroPython.org but found nothing helpful.
                  Finally, I erased the firmware and burned the M5S with the UIFlow-v1.3.1-Beta firmware.
                  It worked, with the code below.
                  >>> import uos
                  >>> uos.sdconfig(uos.SDMODE_SPI,clk=18,mosi=23,miso=19,cs=4)
                  I (53596) gpio: GPIO[23]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pull             down: 0| Intr:0
                  I (53596) gpio: GPIO[19]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pull             down: 0| Intr:0
                  I (53604) gpio: GPIO[18]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pull             down: 0| Intr:0
                  >>> uos.mountsd()
                  W (65959) sdspi_host: spi bus changed (1 -> 2)
                  I (65959) gpio: GPIO[4]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulld             own: 0| Intr:0
                   Mode: SPI
                       Type: SDHC/SDXC
                      Speed: default speed (25 MHz)
                  SPI speed: 40 MHz
                        CSD: ver=1, sector_size=512, capacity=15523840 read_bl_len=9
                        SCR: sd_spec=2, bus_width=5
                  • Z Offline
                    zhufu86
                    Funny...
                    I re-burned back to UIFlow-v1.2.3, and it also worked.
                    >>> import uos
                    >>> uos.mountsd()
                    W (104277) sdspi_host: spi bus changed (1 -> 2)
                     Mode: SPI
                         Type: SDHC/SDXC
                    SPI speed: 20 MHz
                    • Z Offline
                      zhufu86
                      Here I attach the webpages which helps me mostly.
                      Hope it can help other people.
                      https://github.com/loboris/MicroPython_ESP32_psRAM_LoBo/wiki/filesystems
                      https://forum.micropython.org/viewtopic.php?t=4551
                      https://loboris.eu/forum/showthread.php?tid=85
                      Z 1 Reply Last reply Reply Quote 1
                      • Z Offline
                        zhufu86 @zhufu86
                        ok......
                        now even one simple uos.mountsd() also works...
                        good...
                        >>> import uos
                        >>> uos.mountsd()
                        W (497494) sdspi_host: spi bus changed (1 -> 2)
                         Mode: SPI
                             Type: SDHC/SDXC
                        SPI speed: 20 MHz
                          hema41
                          Yes, microSD cards can be accessed in UIFlow or with MicroPython. They allow you to read and write data from/to the microSD card, enabling storage and retrieval of information on compatible devices.
