    M5burner on windows7 cannot flash
    28 Posts 5 Posters 103.8k Views 1 Watching
    • Ariane98A Offline
      Ariane98 @Thrasher
      from m5stack import *
      from m5ui import *
      from uiflow import *
      import imu
      setScreenColor(0x111111)
      imu0 = imu.IMU()
      label0 = M5TextBox(27, 7, "AccX", lcd.FONT_Default,0xFFFFFF, rotate=0)
      setScreenColor(0x33ff33)
      lcd.font(lcd.FONT_DejaVu24)
      lcd.print('FelX', 10, 30, 0xcc33cc)
      wait(3)
      while True:
      label0.setText(str(imu0.acceleration[0]))
      wait(1)
      wait_ms(2)
      • Ariane98A Offline
        Ariane98
        when I try the exact same blocks than in https://www.youtube.com/watch?v=zNxKkfbEkKU (label show get X gyr), I get this "I2C bus error(6)"
        • Ariane98A Offline
          Ariane98
          and from arduino IDE I get values from IMU
          So I guess it has with UIFlow interface to do ?
            Your first issue on the first PC is that for some reason UIFlow is looking at the 2.7 version and not the 3.6 version of python. Check your python environmental setup as this happens if the environment is wrong (I used to get this often when running 2 version of python.
            Second issue. what hardware are you running, what firmware version are you running and what version of UIFlow are you running?
            It sounds like you haven't got UIFlow set to M5Stick.
            • Ariane98A Offline
              Ariane98
              Code runs on the stick, excepted whan I try to use IMU.
              Both firmware and UIFlow are UIFlowv1.3.2
              ajb2k3A Ariane98A 2 Replies Last reply Reply Quote 0
                ajb2k3 @Ariane98
                @ariane98 Which stick?
                The old black or the Orange Stick C?
                • Ariane98A Offline
                  Ariane98 @Ariane98
                  Orange
                  • Ariane98A Offline
                    Ariane98
                    btw, in arduino, how do you access the built in red led?
                    Docs showed pin 10 but it's no working...
                      ajb2k3 @Ariane98
                      @ariane98 said in M5burner on windows7 cannot flash:
                      Try GPIO10
                      Ariane98A 1 Reply Last reply Reply Quote 0
                      • Ariane98A Offline
                        Ariane98 @ajb2k3
                        Strangely, it does light the led when I use digitalWrite(10, HIGH) but then nothing happens with digitalWrite(10, LOW)
                        If I use digitalWrite(10, LOW) first, it sets the led ON...
                          Ok I'm running 1.4 and getting a syntex error.
                          Try upgrading to 1.4.0 beta and try again.
                          • Ariane98A Offline
                            Ariane98 @ajb2k3
                            Thanks for your help
                            I intended to use m5stick with kids but maybe it's too early...
                            Both UIFlow and Arduino environments seem still unpredictable
                              ajb2k3 @Ariane98
                              @ariane98 Its strange because all I use is UIFlow and I am writing an english book on it (samples available to download in the projects forum)
                              For the current M5StickC competition i'm using the IMU in my project however, I'm using the online version and programming over wifi.
                              • Ariane98A Offline
                                Ariane98 @ajb2k3
                                I am using UIFlow online too, but no luck with IMU...
                                • Ariane98A Offline
                                  Ariane98 @ajb2k3
                                  is it possible too use the stick as a vry simple webserver?
                                    Don't know about the web server but here is my imu test file
                                    https://github.com/Ajb2k3/UIFlowHandbook/blob/master/main (8).m5f
                                    • Ariane98A Offline
                                      Ariane98 @ajb2k3
                                      I get the same I2C bus error
                                      If I upload it to the stick I get a grey screen with no data displayed
                                      • Ariane98A Offline
                                        Ariane98 @Ariane98
                                        updated to 1.4.0 beta and that's OK now
                                        Thank you
                                        I've looked at your book...quite nice
                                          ajb2k3 @Ariane98
                                          Thank you
                                          Its still WIP and I am open to comments a criticism.
                                          • lukasmaximusL Offline
                                            @Ariane98 you can check out my guide for simple webserver, it's written for the M5Stack in micropython, but you shouldn't have any problems running it on the stick c https://www.hackster.io/lukasmaximus89/m5stack-micropython-simple-web-server-20a4c4
                                            I'm curious to know what age students were you thinking of using the stick c to teach with?
