    Persistent storage management on the M5Stick-C
    1 Posts 1 Posters 3.6k Views 1 Watching
    • antowanA Offline
      antowan
      I would like to know if it is possible, and if yes how, could I write from micropython a file with telemetry data.
      Just as a precision if it matters, I am using VS code with the M5 plugin to run the python code on the M5Stick-C.
      I've tried the following as a test with no success.
      f = open("log.txt", "w+")
      f.write("Writing content from MicroPython")
      f.close()
      The file is created (but disappear after soft reboot) and stay empty.
      My understanding is that the "flash/" folder is mounted on a FAT filesystem.
      So I would assume that it is possible to write on the micro-controller memory in this space.
      Thank you by advance for your support.
      Regards,
      Antowan
