    Using native idf instead of arduino
    15 Posts 6 Posters 35.3k Views 1 Watching
      rob.biernat
      Ok having had no responses i think i will try and use the code for m5 as an idf component.
      If anyone has already done this then let me know. Idf is a much better environment then arduino however i do understand alot of people get scared writing code
        Thrasher
        Hi Rob,
        I think you will have to start with flashing bootloader (or how its called on esp32) so native IDF would recognize it.
        Keep in mind that some of pins are used by perepherials of M5Stack device
        Anyways keep us updated, I also want more options with M5Stack I find it as great AIO device, just needs a bit more flex to code it with anything suits you most
          rob.biernat
          Idf works fine with m5 stack for everything on the esp32 chip.
          The issue is some bright spark assumed everyone uses arduino
          • lukasmaximusL Offline
            I would love to use esp-idf and start to make some tutorial videos on it, but every time I try to set up the development environment no matter which guide i'm following or which OS i'm on, I always seem to hit a brick wall.
              Thrasher @rob.biernat
              @rob-biernat
              @rob-biernat said in Using native idf instead of arduino:
              Thats mostly because most of us came from Atmega / arduino boards, we are common with it, so why not using it?
              I'm trying to stick with UIFlow / VS Code but its definetly easier to implent most of stuff with 100 years old arduino IDE.
              However, I will give idf ide a try, hopefully I can make it run, Im bit worried Ill burn m5stack's bootloader (still unsure how its realized here)
                rob.biernat @lukasmaximus
                @lukasmaximus i just cloned their gig repo ran a script and away we went
                  rob.biernat @Thrasher
                  @thrasher yeah i understand the background but 90 percent of the code should have been idf with a 10 percent layer for Arduino
                    gig repo? I followed the official esp-idf guide and got as far as it recognizing the xtensa toolchain, but then when I try to make I always get errors and googling those errors hasn't got me anywhere
                      ajb2k3 @lukasmaximus
                      @lukasmaximus said in Using native idf instead of arduino:
                      Same with me
                        rob.biernat
                        Im using idf 4.1 whereas you guys are probrably on the older stuff which was crap.
                        Its cmake based now. Python self installers etc.
                        Anyway I have recompiled arduino as an idf component and got a couple of errors in some libraries but am working through it.
                        I also converted m5 to an idf lib and most of that compiles to apart from the dependecy on arduino SD lib.
                          Any links would be much appreciated, I really want to get stuck in with idf development. I wasn't aware there were any python installer scripts, please enlighten me. I was almost considering an idf docker image I read about.
                            funghy
                            I started from https://github.com/m5stack/esp-adf.git
                            • o.coplestonO Offline
                              o.copleston
                              Hi guys, I came across this thread while trying to fix some M5StickC issues and thought I could chime in with some useful info. You can use Arduino as an ESP-IDF component however, it currently only works up to v3.2.3 of ESP-IDF.
                              If you install v3.2.3 you can then use Arduino as a component from this repo here.
                              Hope this helps.
