    Using native idf instead of arduino
    15 Posts 6 Posters 35.3k Views 1 Watching
      rob.biernat
      Idf works fine with m5 stack for everything on the esp32 chip.
      The issue is some bright spark assumed everyone uses arduino
      • lukasmaximusL Offline
        I would love to use esp-idf and start to make some tutorial videos on it, but every time I try to set up the development environment no matter which guide i'm following or which OS i'm on, I always seem to hit a brick wall.
          Thrasher @rob.biernat
          @rob-biernat
          @rob-biernat said in Using native idf instead of arduino:
          Thats mostly because most of us came from Atmega / arduino boards, we are common with it, so why not using it?
          I'm trying to stick with UIFlow / VS Code but its definetly easier to implent most of stuff with 100 years old arduino IDE.
          However, I will give idf ide a try, hopefully I can make it run, Im bit worried Ill burn m5stack's bootloader (still unsure how its realized here)
            rob.biernat @lukasmaximus
            @lukasmaximus i just cloned their gig repo ran a script and away we went
              rob.biernat @Thrasher
              @thrasher yeah i understand the background but 90 percent of the code should have been idf with a 10 percent layer for Arduino
                gig repo? I followed the official esp-idf guide and got as far as it recognizing the xtensa toolchain, but then when I try to make I always get errors and googling those errors hasn't got me anywhere
                  ajb2k3 @lukasmaximus
                  @lukasmaximus said in Using native idf instead of arduino:
                  Same with me
                    rob.biernat
                    Im using idf 4.1 whereas you guys are probrably on the older stuff which was crap.
                    Its cmake based now. Python self installers etc.
                    Anyway I have recompiled arduino as an idf component and got a couple of errors in some libraries but am working through it.
                    I also converted m5 to an idf lib and most of that compiles to apart from the dependecy on arduino SD lib.
                      Any links would be much appreciated, I really want to get stuck in with idf development. I wasn't aware there were any python installer scripts, please enlighten me. I was almost considering an idf docker image I read about.
                        funghy
                        I started from https://github.com/m5stack/esp-adf.git
                        • o.coplestonO Offline
                          o.copleston
                          Hi guys, I came across this thread while trying to fix some M5StickC issues and thought I could chime in with some useful info. You can use Arduino as an ESP-IDF component however, it currently only works up to v3.2.3 of ESP-IDF.
                          If you install v3.2.3 you can then use Arduino as a component from this repo here.
                          Hope this helps.
