Purchased a m5StickV - Fixed in recent firmware update.
:Fixed!
http://forum.m5stack.com/topic/1403/m5stickv-firmware_1017-upgradeHolding the power button 6 seconds to try turn it off.
It keeps powering back on right away.:edit
reflashed stock.
still can't turn it off.
am i missing a trick?:edit
purged all old drivers from my pc.
reflashed.
fixed.:edit
Problem returned.:edit
i found a few work arounds.-
Cant turn off
Letting the battery run out seems to solve the power button.
As it works fine again afterward. -
Keeps bugging out after running a script in Maix Py ide
Disconnect a reconnect
:edit
device begins doing this when fully charged.:edit
Developers confirmed firmware fixes will be released soon.:Fixed!
http://forum.m5stack.com/topic/1403/m5stickv-firmware_1017-upgrade -
This post is deleted! -
@xeon said in Purchased a m5StickV:
It keeps powering back on right away.-
for the love of all that is holy.
Tell people that sell your device the mic is broken and your looking to dump the project and your losses on it. -
if you make a basic firmware, make sure the off button actually does what the manual says.
the manual covers less than some terrible products.
i can't even understand it's quirks.. connecting via serial reboots it??
Then serial monitor is lost searching.
Starting to think i made a huge mistake.
such a awesome device.. so much potential.:edit
reflashed stock.
am i missing a trick?How did you reflash it, what firmware did you use?
BTW the microphone issue only came up after the release and there was an announcement about the issue -
i used kflash_gui V1.5.3
used the latest firmware.
http://dl.sipeed.com/MAIX/MaixPy/release/master/maixpy_v0.4.0_52_g3b8c18bdo i need a script present ?
Ahh Sorry.. idk what happened.
i apologize if i seem aggressive the device was acting very odd.
i purged my serial drivers and reflashed
http://dl.sipeed.com/MAIX/MaixPy/release/master/maixpy_v0.4.0_52_g3b8c18bSeems to be working as i hoped.
ty for not banning me. -
@xeon No worries, I've been having issues aswell but reflashing does help
the problem came back.
i don't know how.:(
i don't know how.:(
After a reflash the issue is back?
Please email the M5Stack support people. something is defiantly not correct. -
Cant turn off
Same issues here
@fpsychotic
Did yours get very hot while charging? -
@fpsychotic
Did yours get very hot while charging?Yes, mine does get hot
BTW there is already a MK2 on its way. -
Mine cant last long with battery.. I left it to charge for couple of hours and after that it worked maybe 2 minutes.. I keep it plugged into powerbank
Not really and it last some time with battery.
v2? the wifi one? if is not wifi, what is the difference and were you got? -
@fpsychotic I've got the MK1 as the MKII isn't out yet
i verified it.
after reaching 70 to 90% full battery the device wont power off.
it just reboots.
after going below this threshold it turns off again normally. -
Hardmode it with dc-dc stepdown to keep battery outcome always below 70% :))
Well my battery is now rotten thanks to this.
The battery life is fading very fast.I want a replacement.
i bought this device to get a task done.
it's going to. -
@xeon have you contacted M5Stack support about this? They should be available now
