    Purchased a m5StickV - Fixed in recent firmware update.
    25 Posts 4 Posters 91.4k Views 1 Watching
    • X Offline
      Xeon
      :Fixed!
      http://forum.m5stack.com/topic/1403/m5stickv-firmware_1017-upgrade
      Holding the power button 6 seconds to try turn it off.
      It keeps powering back on right away.
      :edit
      reflashed stock.
      still can't turn it off.
      am i missing a trick?
      :edit
      purged all old drivers from my pc.
      reflashed.
      fixed.
      :edit
      Problem returned.
      :edit
      i found a few work arounds.
      1. Cant turn off
        Letting the battery run out seems to solve the power button.
        As it works fine again afterward.
      2. Keeps bugging out after running a script in Maix Py ide
        Disconnect a reconnect
      :edit
      device begins doing this when fully charged.
      :edit
      Developers confirmed firmware fixes will be released soon.
      :Fixed!
      • X Offline
        Xeon
          ajb2k3 @Xeon
          @xeon said in Purchased a m5StickV:
          1. for the love of all that is holy.
            Tell people that sell your device the mic is broken and your looking to dump the project and your losses on it.
          2. if you make a basic firmware, make sure the off button actually does what the manual says.
          3. the manual covers less than some terrible products.
          4. i can't even understand it's quirks.. connecting via serial reboots it??
            Then serial monitor is lost searching.
          Starting to think i made a huge mistake.
          such a awesome device.. so much potential.
          :edit
          reflashed stock.
          How did you reflash it, what firmware did you use?
          BTW the microphone issue only came up after the release and there was an announcement about the issue
          • X Offline
            Xeon
            i used kflash_gui V1.5.3
            used the latest firmware.
            http://dl.sipeed.com/MAIX/MaixPy/release/master/maixpy_v0.4.0_52_g3b8c18b
            do i need a script present ?
            • X Offline
              Xeon @Xeon
              Ahh Sorry.. idk what happened.
              i apologize if i seem aggressive the device was acting very odd.
              i purged my serial drivers and reflashed
              Seems to be working as i hoped.
              ty for not banning me.
                ajb2k3 @Xeon
                @xeon No worries, I've been having issues aswell but reflashing does help
                • X Offline
                  Xeon @ajb2k3
                  the problem came back.
                  i don't know how.
                    ajb2k3 @Xeon
                    i don't know how.
                    After a reflash the issue is back?
                    Please email the M5Stack support people. something is defiantly not correct.
                    • X Offline
                      Xeon @ajb2k3
                      1. Cant turn off
                      • X Offline
                        Xeon
                          FPSychotic
                          Same issues here
                          • X Offline
                            Xeon @FPSychotic
                            @fpsychotic
                            Did yours get very hot while charging?
                              ajb2k3 @Xeon
                              @fpsychotic
                              Yes, mine does get hot
                              BTW there is already a MK2 on its way.
                                Thrasher
                                Mine cant last long with battery.. I left it to charge for couple of hours and after that it worked maybe 2 minutes.. I keep it plugged into powerbank
                                  FPSychotic @ajb2k3
                                  Not really and it last some time with battery.
                                  v2? the wifi one? if is not wifi, what is the difference and were you got?
                                    ajb2k3 @FPSychotic
                                    @fpsychotic I've got the MK1 as the MKII isn't out yet
                                    • X Offline
                                      Xeon
                                      i verified it.
                                      after reaching 70 to 90% full battery the device wont power off.
                                      it just reboots.
                                      after going below this threshold it turns off again normally.
                                        Thrasher
                                        Hardmode it with dc-dc stepdown to keep battery outcome always below 70% :))
                                        • X Offline
                                          Xeon
                                          Well my battery is now rotten thanks to this.
                                          The battery life is fading very fast.
                                          I want a replacement.
                                          i bought this device to get a task done.
                                          it's going to.
                                            ajb2k3 @Xeon
                                            @xeon have you contacted M5Stack support about this? They should be available now
