M5StickV link/Info dump.
hey can anyone confirm me what the value of getBatteryDischargeCurrent() is ? is it mA or battery % ?
@staberas
getBatteryDischargeCurrent() will show you the mA currently being drawn when the device is not being charged. -
@xeon
Thanks, so if the value i get is 100mA then i have ~2hours run time based on the 200mAh battery correct? thou i have to keep the time passed since the last check to estimate battery % -
@staberas
Theoretically yes.
it should be near 2 hours.
under heavy workloads it peaks to +-115mA -
Adding my demo project as a sandbox for other users : https://github.com/staberas/Joker-Masks-M5StickV , it covers faces with joker mask
Can anyone point me on how you use the expansion slot?
@staberas said in M5StickV link/Info dump.:
what expansion slot?
4pin expansion PH2.0-4 -
@staberas The grove port under the USB port?
Does it not work as a normal Grove Port A? -
yes, cant seem to find info on itEDIT: i started testing the pins and i cant detect a voltage output
