    Is it possible to display VGA image on the screen?
    Scheduled Pinned Locked Moved M5Stick V
    7 Posts 4 Posters 14.5k Views 1 Watching
      pnnato
      Anybody know the method to display or resize VGA image (640x480) on the LCD screen?
      It seems like the LCD size is only 240x135 right?
        ajb2k3 @pnnato
        @pnnato the screen of the M5Stack is 320X240. VGA can be displayed but half of it will be offscreen.
        What programming environment are you using?
          What programming enviroment are you using?
            pnnato
            @ajb2k3 I see ... I'm using Python on MaixPy IDE
              Thrasher
              With C its possible to resize image.
              Most likely its possible with python too.
              But keep in mind that if you gonna do that 'on the fly' you FPS would drop significantly
              https://pypi.org/project/python-resize-image/
              Not sure it can be implented with MaixPy tho
                ajb2k3 @Thrasher
                @thrasher I don’t know about miaxpy but you can resize in micro python
                • V Offline
                  vvs551
                  img.resize(240, 135)
