    m5Stack Fire & GPS UIflow > sintax error Why?
    12 Posts 3 Posters 22.5k Views 1 Watching
      almeriBOT
      I have a problem programming the GPS
      I created this code with UIflow
      When I try to run it does not show the data
      When I try to download the program in m5Stack I get an error
      Is there something wrong with my code?
        Thrasher
        It says syntax error, so we better see py code, not blocks. Could you switch to code view and post here?
        For me, setup should not be inside loop. Separate them and try again
          almeriBOT
            almeriBOT
            The biggest problem is that it doesn't show the data
            In the time field it says 00:00:00
            The rest of the fields (latitude, longitude, number of satellites and quality) do not appear data
            I have updated to the latest version 1.4.2
            • m5stackM Offline
              m5stack @almeriBOT
              @almeribot hi maybe just the signal not good , you can go to the outdoor then try a again
                almeriBOT @m5stack
                @m5stack Thank you very much for the reply. I was testing the GPS for more than an hour in an outdoor location
                • m5stackM Offline
                  m5stack @almeriBOT
                  @almeribot so it still doesn't show the data ?
                    almeriBOT
                    I just received an m5Stick. The same program does work on m5Stick. Now I don't understand anything.
                      almeriBOT
                        almeriBOT
                          almeriBOT
                            almeriBOT
