    MQTT subscribes on UiFlow
    23 Posts 6 Posters 91.9k Views 5 Watching
    • world101W Offline
      world101 @robalstona
      @robalstona said in MQTT subscribes on UiFlow:
      @buhi It is possible that the problem is how the data is sent to the mqtt server and how often they are sent. In my case, the sensor data is sent every 25 seconds. And if I run this program it will only show me --- until the server receives new data. and then the channel is subscribed, the data are saved to the variable and displayed on the lcd display. So if you have data updated, for example, every hour, nothing may be displayed for an hour. You can combine something with the "retain" flag when sending data to the server, then you will be able to receive the last data received from the feed. But this already needs to be changed on the device / software side that this data sends.
      https://mntolia.com/mqtt-retained-messages-explained-example
      I opened a request for UIFlow to add support for the retain flag. You can track it here.
      https://github.com/m5stack/UIFlow-Code/issues/1
      • world101W Offline
        world101 @Buhi
        @buhi said in MQTT subscribes on UiFlow:
        @robalstona
        So if i try to get the second one also with mqtt subscribe to a different topic (2nd inverter) the hole screen is black. Any hints?
        Are there any errors on HomeAssistant? I use Adafruit IO and when I get a black screen due to an issue configuring something in UIFlow , typically I can see some errors on the broker’s web console.
        It could be your feed configuration or the sensor data (stored as float or int instead of strings) or something like that.
          skysurfer
          I have the exact same problem. 1 topic works fine, but more does not work.
          • world101W Offline
            world101
            Two topics is working for me with Adafruit IO and this example flow. I'm using uiFlow V1.4.4 and firmware V1.4.3 on the grey M5Stack core (since firmware V1.4.4 currently has some issues).
            I'm not using HomeAssistant and do not have any real sensors that I'm pulling data from. However, the two topics is working for me when I simulate sensor data with button A and B presses, or when I add the data manually via the AIO feed console.
            I'll try to set up HomeAssistant on a RPi and see if anything changes.
              skysurfer @world101
              @world101 Your example does not read the topics, it's being set when you push the buttons....
              • world101W Offline
                world101 @skysurfer
                @skysurfer said in MQTT subscribes on UiFlow:
                You are correct. I'm having the same issues as you.
                • B Offline
                  Buhi
                  Is there really no one that can help us? We are already 3 with the same problem.
                  I don't think that we did the same wrong.
                  Is there a other way to get the values from my mqtt broker or homeassistant? Processing by IFTT or other web service and read the values a different way onto the M5?
                    robalstona @Buhi
                    @buhi there is one more option: you can read / write data from the channel using REST API queries: tab ADVANCED -> HTTP-> HTTP REQUEST. Most MQTT brokers allow this option.
                    When i send http request:
                    https://io.adafruit.com/api/v2/robalstona/feeds/feed01
                    i receive something like that in json format:
                    {"username":"robalstona","owner":{"id":300855,"username":"robalstona"},"id":1207296,"name":"feed01","description":null,"license":null,"history":true,"enabled":true,"visibility":"public","unit_type":null,"unit_symbol":null,"last_value":"20.7","created_at":"2019-10-27T19:40:47Z","updated_at":"2020-01-23T12:01:53Z","key":"feed01","writable":false,"group":{"id":198443,"key":"default","name":"Default","user_id":300855},"groups":[{"id":198443,"key":"default","name":"Default","user_id":300855}]}
                    in my case the "last_value" field with assigned value "20.7" is what I need.
                    You can use JSON->loads json and ADVANCED -> HTTP -> Get Data to store this data in variable as list.
                    only then do you need to know the structure of this list to get to the field with interesting data values
                    • world101W Offline
                      world101
                      Okay, so I was really challenged and determined by this thread to get the setup working. I installed Home Assistant and set up the Mosquitto MQTT add-on. Long story short, I was able to get multiple topics subscribed and working on 3 different devices. Two M5Stacks and one iPhone app called MQTTool. All three devices are publishing and receiving data to/from MQTTT.
                      Here are my uiFlows:
                      M5Stack #1 has an ENV unit providing Temperature, Pressure, and Humidity to MQTT, is reading the status of the LIGHT unit from M5Stack #2, and is reading the status of the iPhone app providing fake sensor/thermostat data. M5Stack #2 has a LIGHT unit providing the digital status of the light sensor (on/off) to MQTT, is reading the T/P/H values provided by M5Stack #1, and is reading the status of the iPhone app providing fake sensor/thermostat data.
                      Troubleshooting the black screen: REPL is your friend for errors. That is ultimately how I figured out what was not working. On a Mac, I opened Terminal and typed this to get to the REPL:
                      screen -port /dev/tty.SLAB_USBtoUART -b 115200
                      As I was building the setup, trying a slightly modified flow on each device, I forgot to connect the unit on the other M5stack. If you have a unit added in uiFlow UI (left side panel) and the unit blocks added to your flow, but the unit is not physically connected to the M5stack, this causes a black screen when attempting to connect to MQTT. No on screen error at all, but the REPL said something like "env0 not found" when I rebooted the M5stack and looked at the startup logs. It would just sit there and hang.
                      Another issue is that the Unit number might be changing on you when you add/remove it from your device or program (i.e. env0 changes to env1 or light0 changes to light1), especially when you don't refresh the entire uiFlow webpage before connecting each new device.
                      Anyway, I hope this helps someone. If you have other scenarios you want me to test, let me know.
                      • B Offline
                        Buhi @world101
                        @world101 Thank you so far for your hard work. I really have to try again.
                        • world101W Offline
                          world101
                          I have some important discoveries... If you have another client device (i.e. MQTTlens, MQTTool, etc.) that sets the retain flag = True on the publish message, that will cause an error on the m5stack MQTT client when you subscribe to multiple topics. Here is the Traceback error.
                          Internal FS (FatFS): Mounted on partition 'internalfs' [size: 2031616; Flash address: 0x210000]
                          Filesystem size: 1978368 B
                                     Used: 585728 B
                                     Free: 1392640 B
                          I (497) [TFTSPI]: attached display device, speed=8000000
                          I (497) [TFTSPI]: bus uses native pins: false
                          [ M5 ] node id:d8a01d698f30, api key:32532B1C
                          I (4783) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
                          I (4784) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
                          I (4935) phy: phy_version: 4100, 2a5dd04, Jan 23 2019, 21:00:07, 0, 0
                          I (4942) modsocket: Initializing
                          Connect Wi-Fi: SSID:xxxxxxxx PASSWD:xxxxxxxx network...
                          Connected. Network config: ('10.0.0.5', '255.255.255.0', '10.0.0.1', '10.0.0.1')
                          Warning: Comparison between bytes and str
                            File "main.py", line 48, in <module>
                            File "flowlib/m5mqtt.py", line 100, in subscribe
                            File "flowlib/simple.py", line 193, in subscribe
                            File "flowlib/simple.py", line 243, in wait_msg
                            File "flowlib/m5mqtt.py", line 52, in _on_data
                          KeyError: b'sensor/light'
                          MicroPython v1.11-319-g54c3f2613-dirty on 2020-01-15; ESP32 module with ESP32
                          So, subscribing to multiple topics seems to be okay in general, but setting the retain flag = True on more than one of those topics seems to cause the MQTT client to throw an error. Also, with lots of debugging, I found that you can only have one topic that has the retain flag = True and it has to be the last one in your micropython code (I think because the code is processed from the bottom up???).
                          This code works. Topics aa, bb, cc, and dd have messages with retain=True. Topics aaa, bbb, ccc, and ddd have messages with retain=False. Topic dd is at the bottom.
                          from m5stack import *
                          from m5ui import *
                          from uiflow import *
                          from m5mqtt import M5mqtt
                          setScreenColor(0x000000)
                          m5mqtt = M5mqtt('m5stickC', '10.0.0.60', 1883, 'mqtt', 'password', 300)
                          label0 = M5TextBox(2, 17, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
                          label1 = M5TextBox(2, 57, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
                          label2 = M5TextBox(2, 96, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
                          label3 = M5TextBox(2, 132, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
                          a = None
                          b = None
                          c = None
                          d = None
                          def fun_aaa_(topic_data):
                            global a, b, c, d
                            a = topic_data
                            label0.setText(str(a))
                            pass
                          m5mqtt.subscribe(str('aaa'), fun_aaa_)
                          def fun_bbb_(topic_data):
                            global a, b, c, d
                            b = topic_data
                            label1.setText(str(b))
                            pass
                          m5mqtt.subscribe(str('bbb'), fun_bbb_)
                          def fun_ccc_(topic_data):
                            global a, b, c, d
                            c = topic_data
                            label2.setText(str(c))
                            pass
                          m5mqtt.subscribe(str('ccc'), fun_ccc_)
                          def fun_dd_(topic_data):
                            global a, b, c, d
                            d = topic_data
                            label3.setText(str(d))
                            pass
                          m5mqtt.subscribe(str('dd'), fun_dd_)
                          m5mqtt.start()
                          while True:
                            wait(1)
                            wait_ms(2)
                          This does not work since topic cc (retain=True) is not at the bottom.
                          from m5ui import *
                          a = None
                          b = None
                          c = None
                          d = None
                            global a, b, c, d
                            a = topic_data
                            pass
                            global a, b, c, d
                            b = topic_data
                            pass
                          def fun_cc_(topic_data):
                            global a, b, c, d
                            c = topic_data
                            pass
                          m5mqtt.subscribe(str('cc'), fun_cc_)
                          def fun_ddd_(topic_data):
                            global a, b, c, d
                            d = topic_data
                            pass
                          m5mqtt.subscribe(str('ddd'), fun_ddd_)
                          m5mqtt.start()
                          while True:
                            wait(1)
                            wait_ms(2)
                          However, if you move the cc topic to the bottom it works again.
                          from m5ui import *
                          a = None
                          b = None
                          c = None
                          d = None
                            global a, b, c, d
                            a = topic_data
                            pass
                            global a, b, c, d
                            b = topic_data
                            pass
                            global a, b, c, d
                            d = topic_data
                            pass
                            global a, b, c, d
                            c = topic_data
                            pass
                          m5mqtt.start()
                          while True:
                            wait(1)
                            wait_ms(2)
                          Hope this helps. Also, I hope @m5stack will update the m5mqtt client to support the Retain flag, QoS, and the Last Will and Testament (LWT) messages soon to solve some of these limitations I have uncovered.
                          S C 2 Replies Last reply Reply Quote 1
                          • B Offline
                            Buhi
                            Ok that could be they key. I will try that out.
                            So many thanks!
                              skysurfer @world101
                              @world101 Makes no difference here...
                              • world101W Offline
                                world101 @skysurfer
                                @skysurfer
                                I can’t help much without knowing your setup. What are you seeing on the REPL or serial monitor? What devices and firmware version are you running? Post your code and I’ll see if I can figure out your issue.
                                  cortado @world101
                                  @world101 Thanx! After making new topics and setting them to QoS=0, and retain=0, it finally works with many MQTT subscriptions on both M5Stack and M5Stick-C! (1.4.4 and 1.4.5)
                                  (PS! Just changing the old topics that had retain back to no retain, did not work, had to make new ones.)
