    UIFLOW does not save python code
    11 Posts 6 Posters 24.8k Views 2 Watching
      Thrasher
      Yes, its been so since beginning. We hope it will be implented soon
      • sysdl132S Offline
        sysdl132
        UIFlow cannot save python code.You can save .py file in visual studio.
        For Atom:115200/230400/921600
        • world101W Offline
          world101
          The only way to get custom code to save within UIFlow is to...
          • add it to the Execute block (under Advanced)
          • Create your own custom blocks with http://block-maker.m5stack.com/
          • M5StickFreaklerM Offline
            M5StickFreakler @sysdl132
            @sysdl132 Yes, but it is confusing because I can save it, but nothing is saved :-)
            • sysdl132S Offline
              sysdl132
              If you want to download visual studio,click me
              M5StickFreaklerM 1 Reply Last reply Reply Quote 1
                @sysdl132 said in UIFLOW does not save python code:
                No problem, already installed (I'm a developer). Its just dangerous if someone save a file in UiFlow and then nothing is in it. So maybe m5stack should disable the save button if you are in py-code. :-)
                  ajb2k3 @M5StickFreakler
                  @m5stickfreakler only the blocks are saved not micropython code. This has been the same since the beginning.
                    M5StickFreakler @ajb2k3
                    @ajb2k3 said in UIFLOW does not save python code:
                    What will you say with that? I know it is not saving micropython code - that's the point!
                    Again: If I have the python code in front of you and then save it, then it is not saved and you don't see that.
                    A good UI does not allow such things.
                    So in my opinion there are two solutions:
                    • It is not possible to use the save function if switched to python code
                    • or it saves a py-file if switched to python code
                      Thrasher
                      Just use vs code lol
                      You can run uiflow dual-box to check for m5 libraries code and simply copy strings to vs code
                        flypeek
                        Import large MicroPython scripts with UIFlow
                        https://qiita.com/ciniml/items/68bc7f362d6985efc640
