    M5StickC/ATOM on MacOS Catalina can't upload/ ESP32: Timed out waiting for packet header solution (Solved)
    44 Posts 19 Posters 269.9k Views 6 Watching
      cepics
      I have problems to upload code on M5StickC and M5Atom LITE.....
      no serial port available in tools/port menu..
      I have also burn with easyloader (on a win machine) to reset the modules
      osx 10.12.5
      arduino IDE 1.8.9
      • m5stackM Online
        m5stack @cepics
        @cepics you could try setup the baud to 115200. then try again. or contact our store. we will help you solve it. as soon as possible
          HerrLehmann @m5stack
          @m5stack
          I'm on macos 10.15.3 and I'm asking myself too, where is G0 on the M5Atom Matrix? Although I was able to apply the described firmware, I'm not able to connect via UIFlow IDE nor Arduino IDE (1.8.9).
          By the way: almost no image gets displayed on Safari from the documentation — neither iPad nor mac.
          • m5stackM Online
            m5stack @HerrLehmann
            @herrlehmann M5Atom Matrix have not provided G0 Pin to outside. so the solustion 1 is for m5stickC. and could you use windows os test it again? maybe is the driver software problem .
              cepics @m5stack
              @m5stack said in M5StickC and ATOM on MacOS Catalina can't upload programs solustion:
              no way!!! Atom serial port doesn't appear in the serial port list..... more than one cable tested....
                @m5stack
                No, the is (un)fortunately no Windows machine. I'm a little confused about the fact, that the above mentioned firmware is running without any problem. So there needs to be a connection between mac to m5atom in some way — or how is it writing to the device?
                  RschDev
                  My new m5stick-C are showing up on the MacOS (10.15.3) as M5 Serial Converter, and in the Arduino IDE (latest edition). I have applied the updater as suggested in this thread, and still get this response when trying to upload from the IDE to the device: "fork/exec /Applications/Arduino 2.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags: bad CPU type in executable
                  Error compiling for board M5Stick-C."
                  • m5stackM Online
                    m5stack @RschDev
                    @rschdev clearly. this is a compiling error . you should check the error information , and check you program.
                    • m5stackM Online
                      @herrlehmann did you installed the FTDI driver? you could try delete both below files. then connect your device try again.
                      /Library/Extensions/FTDIUSBSerialDriver.kext
                      /Library/Extensions/FTDIKext.kext
                      H 2 Replies Last reply Reply Quote 0
                        I had access to a Windows machine and was able to use the easy loader on my M5Atom Matrix. It is working on Windows.
                        For my mac:
                        Yes, I installed the FTDI driver, but they did not work. I've removed them as suggested, but it didn't change anything. There is still no device appearing in /dev/, so it is not accessible.
                          @m5stack did you dig any deeper into this? I'm still unable to use the M5Atom Matrix on my mac with Catalina. I started over again by installing and deinstalling stuff, but no new device appears. The system recognizes the M5Atom Matrix by naming a M5 Serial Converter with following information:
                          Produkt-ID: 0x6001
                          Hersteller-ID: 0x0403 (Future Technology Devices International Limited)
                          Version: 4.00
                          Seriennummer: 79525701B4
                          Geschwindigkeit: Bis zu 12 MBit/s
                          Hersteller: M5STACK Inc.
                          Standort-ID: 0x14500000 / 6
                          Verfügbare Stromstärke (mA): 500
                          Erforderliche Stromstärke (mA): 100
                          Zusätzlicher Betriebsstrom (mA): 0
                          I also applied the firmware update many times successfully.
                          @m5stack : Any other ideas? I'd like to play with it.
                          • m5stackM Online
                            @herrlehmann did you have try to install the FTDI driver : https://www.ftdichip.com/Drivers/VCP.htm
                              Pumpui @nsfilho
                              @nsfilho don't update to 10.15.04....
                                @m5stack : Yes, I did. By further investigating the driver, it looks like they are not working due to signing issues. I found this thread https://www.ftdicommunity.com/index.php?topic=409.msg1171#msg1171
                                I'm waiting on this rerelease, than I'll let you know. Thanks.
                                  climbingrose
                                  I'm trying to apply firmware update on Catalina and having this error message:
                                  Detecting M5Stack products.
                                  Find M5Stack products.
                                  Kernel driver deteched.
                                  Apply magic success.
                                  Fail to cast magic stage 2, please contact vendor
                                  Wating for device in DFU mode..................................
                                  Any idea?
                                  R F 2 Replies Last reply Reply Quote 2
                                    Re4DeR @climbingrose
                                    @climbingrose I have same problem. Have you found any solution?
                                      Finnsen @climbingrose
                                      @climbingrose I have that same problem as well. It would be nice if @m5stack could support their products in a better manner and give us a good receipt to fix the issues.
                                      • m5stackM Online
                                        m5stack @Finnsen
                                        @finnsen if you try these solution still can't solve the problem. you could contact the store
                                          Finnsen @m5stack
                                          @m5stack What do you mean by contacting the store, how can they help me resolve the issue? Or do you mean to return the product?
                                          lukasmaximusL m5stackM 2 Replies Last reply Reply Quote 0
                                          • lukasmaximusL Offline
                                            lukasmaximus @Finnsen
                                            @finnsen I didn't catch what you were trying to flash to your device, if you are trying to update uiflow firmware on the device with M5Burner and it fails, have you tried using esptool to flash firmware? if you were uploading an arduino program there are known issues with all esp32 devices on catalina not just m5stack https://github.com/arduino/Arduino/issues/9438 I did make a video a while back ( https://www.youtube.com/watch?v=MTCjKhVKOto) about using m5stack devices on catalina and I didn't seem to come across any of the issues you mentioned, perhaps the issues are with a later revision of catalina, I'll update and take a look when I get chance.
