    M5stack programming without Arduino IDE : how ?
    23 Posts 9 Posters 127.1k Views 3 Watching
      jrs @JJ
      @jimit
      Yes, the install was done with git cloning
      I'll try again tomorrow to better trace the errors
      Thanks for your hints so far, I value your help
      • JJJ Offline
        JJ @jrs
        @jrs No problem.... Yes more details on the errors or maybe mention what you are trying to compile if it is a known program/sketch. Don't think I can be of any further help but with more details someone else may have some answers.
        J 2 Replies Last reply Reply Quote 0
        • loborisL Offline
          loboris
          @jrs
          When building with esp-idf you can use M5Satck just like any other ESP32 development board.
          All esp-idf examples, for example, will run on M5Stack same as on any other board.
          You may have some issues when using C++. Please cunsult the documentation and ESP32 forum. There are many threads related to C++ issues/questions.
            jrs @JJ
            @jimit
            I have re-installed esp-idf and compiling a project for the WRover kit works nicely, as always.
            Next, I have cloned M5Stack-IDF but it is not clear in my minds where the directory should go. Should individual components be copied into esp-idf's own components directory ?
            As per the M5Stack documentation (https://github.com/m5stack/M5Stack-IDF), make menuconfig should have some Arduino option ... but I don't see any
            All other compilation issues could stem from this initial installation/configuration mistakes on my side.
            Any idea ?
            TIA for your help !
              jrs @JJ
              @jimit
              Now, make menuconfig has Arduino options.
              I had followed
              which lacks some parts of
              https://github.com/m5stack/M5Stack/blob/master/docs/esp-idf_component.md
              But now, when trying to use M5.xxx functions, the #include <M5Stack.h> yields in a missing M5Stack.h message.
              I keep searching to solve the issues
              • JJJ Offline
                JJ @jrs
                @jrs Hi,
                I checked my ESP-IDF and i still have setup issues.
                Under Windows, I have the ESP-IDF directory and the M5Stack-IDF directory both installed in their own separate directory located at: c:\Users\myusername
                I set this up many weeks ago so I don't recall what led me to install the directories there or if that is correct.
                RE - Your last error message: "when trying to use M5.xxx functions, the #include <M5Stack.h> yields in a missing M5Stack.h message."
                This is where I have that file located:
                C:\Users\myusername\M5Stack-IDF\components\M5Stack\src\M5Stack.h
                I don't suppose it gave you any suggestion where it expected to find this file ?
                Which OS are you running ?
                Thanks for adding the links. They will be useful.
                  jrs @JJ
                  @jimit
                  I am running Mac OS
                  In my setup the M5Stack-IDF is in esp-idf.
                  I achieved to run esp-idf hello-world example on the M5Stack but I need to use M5 specific functions, hence the need for M5Stack.h I guess
                  The content of hello_world is (sorry indentation is not kept by this site FAQ engine):
                  build/
                  components/
                  arduino/
                  appveyor.yml
                  boards.txt
                  component.mk
                  cores/
                  docs/
                  Kconfig
                  libraries/
                  Makefile.projbuild
                  package/
                  package.json
                  platform.txt
                  programmers.txt
                  README.md
                  tools/
                  variants/
                  main
                  component.mk
                  hello_world_main.c
                  Makefile
                  README.md
                  sdkconfig
                  sdkconfig.old
                  I'll keep on tomorrow
                  • JJJ Offline
                    JJ @jrs
                    @jrs Glad you seem to have it working.
                    Since yours is working, it should be safe to assume your setup is correct: with M5Stack-IDF installed in the ESP-IDF directory.
                    Thanks for the update....
                      Calin
                      The easyest way to start with ESP-IDF is by PlatformIO
                      That IDE include ESP-IDF, Arduino, Mbed...
                      JJJ 1 Reply Last reply Reply Quote 2
                      • JJJ Offline
                        JJ @Calin
                        @calin Great tip re. PlatformIO - will take it for a spin...
                        • wtakuoW Offline
                          wtakuo
                          Hello.
                          I started to use M5Stack a month ago. I tried several simple projects using Arduino IDE. Before moving to ESP-IDF based development, I tried a trivial (hello world) project to test my settings.
                          Unfortunately, current https://github.com/m5stack/M5Stack-IDF looks outdated and incomplete. So I use https://github.com/m5stack/M5Stack as an IDF component as well as https://github.com/espressif/arduino-esp32 .
                          The project directory looks like the following.
                          Makefile
                          sdkconfig
                          components/
                              arduino/            (recursive clone of https://github.com/espressif/arduino-esp32, idf-update branch)
                              M5Stack/            (clone of https://github.com/m5stack/M5Stack)
                                  component.mk    (should be modified. See below)
                          main/
                              component.mk
                              main.cpp            (copy of components/M5Stack/examples/Basics/Hello/Hello.ino)
                          The only tweak I did is the addition of src/utlitity to the end of these path variables in components/M5Stack/component.mk.
                          COMPONENT_SRCDIRS := . src src/utility
                          COMPONENT_ADD_INCLUDEDIRS := . src src/utility
                          Without this modification, make cannot correctly find the source codes and headers under src/utility.
                          The above setup looks OK and works for other projects.
                          My questions are:
                          * Is this a correct setup for ESP-IDF projects? (Is there any better one?)
                          * Is there any way to avoid the modification of components/M5Stack/component.mk?
                          Thank you for attention.
                          • wtakuoW Offline
                            wtakuo
                            My forked and updated version (implementing the setup in my previous post) of M5Stack-IDF template project is available: https://github.com/wtakuo/M5Stack-IDF
                            dasloloD wtakuoW 2 Replies Last reply Reply Quote 1
                            • dasloloD Offline
                              daslolo @wtakuo
                              @wtakuo Thank you!
                              • wtakuoW Offline
                                wtakuo @wtakuo
                                I fixed my patch in https://github.com/wtakuo/M5Stack-IDF.
                                The path variables in component.mk should look like the following.
                                COMPONENT_SRCDIRS := src src/utility src/Fonts
                                COMPONENT_ADD_INCLUDEDIRS := src
                                As shown in the above code, I added src/Fonts to COMPONENT_SRCDIRS and removed unnecessary "." (current directory) from both paths. Header files in the subdirectories are specified using relative paths from src. So we don't need to add these subdirectories to COMPONENT_ADD_INCLUDEDIRS.
                                Anyway, I sent pull request regarding this fix. If my PR is accepted, the patch file in https://github.com/wtakuo/M5Stack-IDF will be unnecessary.
                                wtakuoW 1 Reply Last reply Reply Quote 0
                                • wtakuoW Offline
                                  wtakuo @wtakuo
                                  Now my PR has just been incorporated into the latest commit of M5Stack. So I removed patch.txt.
                                  In addition, to tidy up the repository of my fixed M5Stack-IDF, I moved my modifications to components_patch branch. So main branch no longer contains the fix now. If you'd like to try my fixed version of M5Stack-IDF, please do like the following commands.
                                  git clone --recursive -b components_patch https://github.com/wtakuo/M5Stack-IDF.git
                                  Sorry for inconvenience due to the changes.
                                  • JJJ Offline
                                    JJ @wtakuo
                                    @wtakuo
                                    Hi wtakuo,
                                    thanks for your work on this…. Nice that M5Stack included your work.
                                    Your efforts inspired me to give installation another crack – this time using Linux instead of Windows. MUCH better so far.
                                    Just have to determine which serial port is in use… got a long list rather than a defined port when following the ESP-IDF setup guide that outlined how to distinguish the serial port in use. Will follow it up laterz.
                                      hetlelid
                                      For reference:
                                      Arduino submodule failed. I downloaded the latest, like this (and working):
                                      rm -r components/arduino/
                                      git clone https://github.com/espressif/arduino-esp32.git components/arduino-esp32
                                      cd components/arduino-esp32 && git submodule update --init --recursive && cd ../..
                                      Nice if this could be fixed in the code, wtakuo :)
                                      • m5-docsM Offline
                                        m5-docs
                                        Here is the article about programming with Arduino IDE
                                        For Windows:
                                        https://m5stack.readthedocs.io/en/latest/get-started/m5stack_core_get_started_Arduino_Windows.html
                                        For MacOS:
                                        https://m5stack.readthedocs.io/en/latest/get-started/m5stack_core_get_started_Arduino_MacOS.html
                                        M5Stack documentation URL
                                        https://docs.m5stack.com
