    M5stack programming without Arduino IDE : how ?
    23 Posts 9 Posters 127.1k Views 3 Watching
      jrs @JJ
      @jimit
      I am running Mac OS
      In my setup the M5Stack-IDF is in esp-idf.
      I achieved to run esp-idf hello-world example on the M5Stack but I need to use M5 specific functions, hence the need for M5Stack.h I guess
      The content of hello_world is (sorry indentation is not kept by this site FAQ engine):
      build/
      components/
      arduino/
      appveyor.yml
      boards.txt
      component.mk
      cores/
      docs/
      Kconfig
      libraries/
      Makefile.projbuild
      package/
      package.json
      platform.txt
      programmers.txt
      README.md
      tools/
      variants/
      main
      component.mk
      hello_world_main.c
      Makefile
      README.md
      sdkconfig
      sdkconfig.old
      I'll keep on tomorrow
      • JJJ Offline
        JJ @jrs
        @jrs Glad you seem to have it working.
        Since yours is working, it should be safe to assume your setup is correct: with M5Stack-IDF installed in the ESP-IDF directory.
        Thanks for the update....
          Calin
          The easyest way to start with ESP-IDF is by PlatformIO
          That IDE include ESP-IDF, Arduino, Mbed...
          JJJ 1 Reply Last reply Reply Quote 2
          • JJJ Offline
            JJ @Calin
            @calin Great tip re. PlatformIO - will take it for a spin...
            • wtakuoW Offline
              wtakuo
              Hello.
              I started to use M5Stack a month ago. I tried several simple projects using Arduino IDE. Before moving to ESP-IDF based development, I tried a trivial (hello world) project to test my settings.
              Unfortunately, current https://github.com/m5stack/M5Stack-IDF looks outdated and incomplete. So I use https://github.com/m5stack/M5Stack as an IDF component as well as https://github.com/espressif/arduino-esp32 .
              The project directory looks like the following.
              Makefile
              sdkconfig
              components/
                  arduino/            (recursive clone of https://github.com/espressif/arduino-esp32, idf-update branch)
                  M5Stack/            (clone of https://github.com/m5stack/M5Stack)
                      component.mk    (should be modified. See below)
              main/
                  component.mk
                  main.cpp            (copy of components/M5Stack/examples/Basics/Hello/Hello.ino)
              The only tweak I did is the addition of src/utlitity to the end of these path variables in components/M5Stack/component.mk.
              COMPONENT_SRCDIRS := . src src/utility
              COMPONENT_ADD_INCLUDEDIRS := . src src/utility
              Without this modification, make cannot correctly find the source codes and headers under src/utility.
              The above setup looks OK and works for other projects.
              My questions are:
              * Is this a correct setup for ESP-IDF projects? (Is there any better one?)
              * Is there any way to avoid the modification of components/M5Stack/component.mk?
              Thank you for attention.
              • wtakuoW Offline
                wtakuo
                My forked and updated version (implementing the setup in my previous post) of M5Stack-IDF template project is available: https://github.com/wtakuo/M5Stack-IDF
                dasloloD wtakuoW 2 Replies Last reply Reply Quote 1
                • dasloloD Offline
                  daslolo @wtakuo
                  @wtakuo Thank you!
                  • wtakuoW Offline
                    wtakuo @wtakuo
                    I fixed my patch in https://github.com/wtakuo/M5Stack-IDF.
                    The path variables in component.mk should look like the following.
                    COMPONENT_SRCDIRS := src src/utility src/Fonts
                    COMPONENT_ADD_INCLUDEDIRS := src
                    As shown in the above code, I added src/Fonts to COMPONENT_SRCDIRS and removed unnecessary "." (current directory) from both paths. Header files in the subdirectories are specified using relative paths from src. So we don't need to add these subdirectories to COMPONENT_ADD_INCLUDEDIRS.
                    Anyway, I sent pull request regarding this fix. If my PR is accepted, the patch file in https://github.com/wtakuo/M5Stack-IDF will be unnecessary.
                    wtakuoW 1 Reply Last reply Reply Quote 0
                    • wtakuoW Offline
                      wtakuo @wtakuo
                      Now my PR has just been incorporated into the latest commit of M5Stack. So I removed patch.txt.
                      In addition, to tidy up the repository of my fixed M5Stack-IDF, I moved my modifications to components_patch branch. So main branch no longer contains the fix now. If you'd like to try my fixed version of M5Stack-IDF, please do like the following commands.
                      git clone --recursive -b components_patch https://github.com/wtakuo/M5Stack-IDF.git
                      Sorry for inconvenience due to the changes.
                      • JJJ Offline
                        JJ @wtakuo
                        @wtakuo
                        Hi wtakuo,
                        thanks for your work on this…. Nice that M5Stack included your work.
                        Your efforts inspired me to give installation another crack – this time using Linux instead of Windows. MUCH better so far.
                        Just have to determine which serial port is in use… got a long list rather than a defined port when following the ESP-IDF setup guide that outlined how to distinguish the serial port in use. Will follow it up laterz.
                          hetlelid
                          For reference:
                          Arduino submodule failed. I downloaded the latest, like this (and working):
                          rm -r components/arduino/
                          git clone https://github.com/espressif/arduino-esp32.git components/arduino-esp32
                          cd components/arduino-esp32 && git submodule update --init --recursive && cd ../..
                          Nice if this could be fixed in the code, wtakuo :)
                          • m5-docsM Offline
                            m5-docs
                            Here is the article about programming with Arduino IDE
                            For Windows:
                            https://m5stack.readthedocs.io/en/latest/get-started/m5stack_core_get_started_Arduino_Windows.html
                            For MacOS:
                            https://m5stack.readthedocs.io/en/latest/get-started/m5stack_core_get_started_Arduino_MacOS.html
                            M5Stack documentation URL
                            https://docs.m5stack.com
