    [Solved] https request ends in error 12: "ENOMEM"
    3 Posts 2 Posters 9.1k Views 1 Watching
    • M5StickFreaklerM Offline
      M5StickFreakler
      Hi folks
      Is there a possibility to make https request, instead of http request?
      Nowadays there is nearly no web site out there that allows http.
      Everything is https. I would like to get info from an api that provides weather data.
      Or is the received data simply to large? I get an error: 12 ENOMEM.
      The received data is about 8k
      Thanks for help :-)
      Best regards
      Thomas
      ADDED "SOLUTION":
      It works just if I upload the program to the device, but not in RUN-mode :-(
      Does anyone have a better solution?
        joscha
        I can see the same with FW 1.4.5.1 and USB mode. If I use web mode it works. The request itself is HTTPS but tiny.
        This might be related: https://github.com/m5stack/UiFlow-Bug-Report/issues/34
          M5StickFreakler
          It works with Firmware V1.5.1 and above
