    [Solved] Pb.Hub and Pa.Hub grayed out?
    5 Posts 3 Posters 10.1k Views 1 Watching
    • M5StickFreaklerM Offline
      M5StickFreakler
      Hi folks
      With newest UIFlow Desktop Software V 1.0.9.1 the Units Pb.Hub and Pa.Hub are grayed out.
      I have buyed it some weeks ago and now it is not supported anymore?
      Why????
      Do I something wrong?
      Best regards
      Thomas
      • m5stackM Online
        m5stack @M5StickFreakler
        @m5stickfreakler you could select the 1.5.1 (beta) version in the navigation. then will solve this problem
          M5StickFreakler @m5stack
          @m5stack said in Pb.Hub and Pa.Hub grayed out?:
          Hi
          I have installed Firmware 1.5.1 on my M5Stack Fire devices.
          The problem ist not the firmware, but the Desktop UIFlow Version 1.0.9.1.
          That has nothing to do with the firmware Version of the device.
          Or do I something missunderstand?
          Best regards
          Thomas
          • SkinkS Offline
            Skink
            @M5StickFreakler
            Start the Desktop IDE Version (Offline Version) of UIFlow, then go to "CheckUpdate" there you start the update to the new version 1.0.9.1 then Pb.HUB and Pa.HUB are activated again and you can access them !
            THERMAL and HEAT UNITS are the only ones that are greyed out in this version !
            You may have to install the software completely again !?
            greetings skink
              M5StickFreakler @Skink
              @skink said in Pb.Hub and Pa.Hub grayed out?:
              @M5StickFreakler
              greetings skink
              Hi skink
              This was my mistake.
              I have already the newest version of UI-Flow installed but I didn't realized, that I have to change the Version via the following button too:
              So I have switched to V1.5.1 and now the pa.Hub and Pb.Hub aren't grayed out.
              Too dumb of me.
              Thank you and best regards
              Thomas
