    how many floors?
    5 Posts 4 Posters 13.9k Views 2 Watching
      richardmike4
      how many floors can have the m5stack?
      • JJJ Offline
        JJ @richardmike4
        @richardmike4
        Behold - the M5Stack Tower !
        Hi Richard,
        I don't think there is a hard limit on the number of "floors" or "stacks" that can be used with the M5Stack.
        Behold - the M5Stack Tower below !! Using a total of 9 stacks, including Battery module , Lora module and 5x Proto modules.
        Note there are some limitations on how the stacks can be used:
        • I would suggest only using one battery module per stack.
        • Some modules use the same GPIO - in this case only one module can be actively used at a time.
        • The GPS and SIM modules use the same GPIO - the GPS continually sends data - so here it should not be used in the stack at the same time as GSM module.
        R C 2 Replies Last reply Reply Quote 1
          richardmike4 @JJ
          @jimit thank you very much
            Calin @JJ
            @jimit 在 how many floors? 中说:
            @richardmike4
            "hack" one of them and move the rx/tx lines to different GPIO's then use serial1 to connect to that module.
            Then you have 2 serial's and you can use both modules simultaneously.
            When there is will, there is a way :D
            dasloloD 1 Reply Last reply Reply Quote 2
            • dasloloD Offline
              daslolo @Calin
              @calin the bottom stack should be the watch 😂
