    UIFlow 1.5.1
    15 Posts 6 Posters 27.2k Views 2 Watching
      I'm getting issues with using the earth unit on fw 1.5.1
      uiflow is calling adc instead of earth
        @m5stack FW1.5.1 and UIFLow web 1.5.1
        When trying to use the earth sensor (2 prong moisture sensor) firmware respond with Unit ADC and no function getRawValue.
        • m5stackM Online
          m5stack @ajb2k3
          @ajb2k3 OK, Thank you feedback. we will fix this bug as soon as possible
          • m5stackM Online
            m5stack @plusulli
            @plusulli for the time being, M5StickC don't have 1.5.1 FW. pls patient wait.
              ajb2k3 @m5stack
              @m5stack AttributeError 'i2c' object has no attribute 'begin'
              • m5stackM Online
                m5stack @ajb2k3
                @ajb2k3 after what operation it return this error?
                  ajb2k3 @m5stack
                  @m5stack Sorry should have said.
                  Trying to use the NCIR unit on port A
                  • m5stackM Online
                    m5stack @ajb2k3
                    @ajb2k3 ok......we will tracking this issues
                      @m5stack DCMotor and fan can not be controlled using PWM.
                      • G Offline
                        Guors
                        @m5stack FYI! I receive the error "DAC object has no attribute 'waveform' " in UIFlow when using the "dac0 waveform with..." block. Is this due to the last firmware? Thanks!
                          Pumpui @M5StickFreakler
                          • m5stackM Online
                            m5stack @Guors
                            @guors thank you feedback. we will fix this bug as soon as possible
