    UIFlow 1.6.2
    17 Posts 4 Posters 31.7k Views 4 Watching
    • m5stackM Offline
      UpdateLog:
      Ver 1.6.2 time : 2020.08.07
      firmware:
      • V-Function: support Line Tracker&Tag reader..
      • Image: PNG support..
      • StickC-Plus beep support..
      • IR unit bug fix..
      • Therad mutex bug fix..
      • Other bugs fix..
      • Core2: Speaker support(Only support play WAV file for now)..
      • Core2: Vibration motor intensity setting support..
      • Core2: Checkbox widgets support..
      • Core2: Slider bar widgets support..
      • Core2: Bar widgets support..
      web:
      • Add: V function support Line Tracker&Tag reader
      • Add: Core2 Slider, Bar, Checkbox component
      • Fixed some bugs.
        plusulli
        It'd be nice if there were demos for the V-function. I can't get anything done
        • m5stackM Offline
          m5stack @plusulli
          @plusulli we had provided tutorial in the document.
          https://docs.m5stack.com/#/en/quick_start/unitv/v_function
          • SkinkS Offline
            Skink
            When will the Desktop UIFlow version 1.6.2 be released !
              João Silva @m5stack
              @m5stack
              Hellow everibody!
              Realy, i'm a new one at this mater but, I like them .
              I baugt some kits arduino, including the M5GO IoT Starter v1.0
              I started reading all papers including, reading the procedings to configuration,
              specialy the wifi connection.
              At a time, I receved a message from the the UIFlow page telling me it would be better to update de firmware to the V1.6.2 version. So, I do that! Using the M5 Burner. So! After this, the M5GO was staing diferent, never could more config the wifi connection, and so on. After many times traing the M5 Burner, and other things, acidentaly I erased the firmware at my M5GO.
              SO, I'm asking you, the grate masters, for your help or only if I'll go yet revive it!
              This because, After the death of M5GO Stack, I traid the M5 Burner page and I get always an error message from the Java Script software. The M5GO always conneted by USB cable.
              Many Thanks in Advance
              João Silva, Portuguese , 70 years old
              The better things for your lifes
              • m5stackM Offline
                m5stack @João Silva
                @joão-silva what error info alert in the M5Burner ?
                you could follow this tutorial to learn how to configuration wifi etc in the new UIFlow firmware version
                https://docs.m5stack.com/#/en/quick_start/m5core/m5stack_core_get_started_MicroPython
                • m5stackM Offline
                  m5stack @Skink
                  @skink coming...soon
                    João Silva @m5stack
                    @m5stack
                    This is the error message from Java Script when I do save at the window " wifi config " at M5 Burner
                    I'll study the tutorial
                    Many Thanks My Friend
                      João Silva @João Silva
                      @joão-silva said in UIFlow 1.6.2:
                      @m5stack
                      Note: the drive CP210X was already installed!
                      • m5stackM Offline
                        m5stack @João Silva
                        @joão-silva try to open with administrator rights
                          João Silva
                          @m5stack
                          Well, now I cann't continue because this ...
                            @m5stack
                              @joão-silva
                              ... well, the last weekend was hard ! I'm now iniciating as administrator; I'm definined with total control.
                              Unhappelly, I continue with that message but I do no why!!
                              Can you continue help me? Thanks a lot!!
                                @joão-silva
                                This happen when I try to configure UIFlow from the M5Burner software, before Burning. What meanes?
                                This is the window at M5Burner that I'm speaking.
                                Is it necessary to change anything before Saving?
                                When I press Save, appear the error message again.
                                • SkinkS Offline
                                  Skink
                                  @m5stack
                                  In the past the updates of the UiFlow IDE took a maximum of one week, now almost one month has passed the IDE software is still 1.6.1 and online is already 1.6.3 !
                                  When will the offline version be updated !?
                                    João Silva
                                    My Windows 10 was bloking the processo ! It is fixed. But, now I have a problem with the comunication port.
                                    Can you interpret the imagies at top of the message, for me, please?
                                    Thanks.
                                    • m5stackM Offline
                                      we haven't met this situation. maybe you could check if there is firewall software. or try again another PC environment.
