    UIFlow 1.6.3
    19 Posts 9 Posters 37.8k Views 2 Watching
      @m5stack there is an alignment issue with the German version of the Web UIFlow, looks like the formatting has been broken.
      • V Offline
        veryalien
        The vibration motor intensity setting has no effect. Setting it to any value between 0 and 100 does not change the motor at all. The motor is always fully on when it is enabled.
        • m5stackM Offline
          m5stack @ajb2k3
          @ajb2k3 thanks feedback. we will fix it ASAP
            klapaucius
            This may be a super stupid question but where are the download links for the recent firmwares ?
            On MacOS, M5burner shows just and empty screen. The flow.m5stack.com site does not show firmware download links (just links to the m5burner tool containing no firmware).
            https://github.com/m5stack/M5Stack-Firmware/blob/master/firmware-repo.list only shows outdated firmware (which I can upload manually using the flash.sh script after sufficient massaging).
            Also note that the UIflow desktop app does not seem to work - it looks like the baud rate might be too high for the mac.
            Thanks in advance for clarifying!
              kurthofman
              Hello, I've upgraded my M5Stack Fire too 1.6.3 but the device doesn't boot anymore.
              I get :
              E (433) esp_image: invalid segment length 0xffffffff
              E (433) boot: Factory app partition is not bootable
              E (433) boot: No bootable app partitions in the partition table
              Can this be solved !
                ajb2k3 @kurthofman
                @kurthofman to you upgrade to the correct version of 1.6.3?
                there is 3 versions for the core
                  klapaucius @ajb2k3
                  Is there a download link for the latest firmwares ? The M5burner on MacOS seems broken (I can into details if you want me to), but I can flash firmware manually without problems. But I can't find download links published anywhere.
                  Many thanks in advance!
                    klapaucius @ajb2k3
                    • SkinkS Offline
                      Skink
                      @kurthofman
                      Here is a breakdown of the versions for the respective M5 Core's
                      what I don't know exactly is if M5 Core Lite and M5GO are not also part of M5Core Fire.
                      • SkinkS Offline
                        Skink @veryalien
                        @veryalien
                        Yes I have to agree with you, I have the same problem.
                        With "Set vibration intensity" alone the vibration motor does not work at all, no matter if 1-100%.
                        If I switch it on with "Set vibration enable (true)" the motor will vibrate but with the same intensity, I try to change the intensity with "Set vibration intensity" but nothing happens.
                        I can only switch it off with "Set vibration enable (false)"!
                          ajb2k3 @Skink
                          @skink the lite and the go are Mark 1 cores
                          • G Offline
                            GMAN
                            Bug report: firmware 1.6.3-en is not installing on M5 stack core (black) 1.6.2 does.
                            • m5stackM Offline
                              m5stack @GMAN
                              @gman what is your mean? can't install the firmware file? or can't burn the firmware? could you say more detail?
