    UIFlow 1.8.0
    31 Posts 11 Posters 92.4k Views 2 Watching
    • m5stackM Offline
      m5stack @OyczE
      @mati you could try 0001 for the mask code
      • m5stackM Offline
        m5stack @OyczE
        @mati did you open more than two UIFlow web pages? if you open two pages in the same browser and use different hardware. that would have some conflict. so I think you just need to open a new browser. it will work fine.
        OyczEO 2 Replies Last reply Reply Quote 0
        • OyczEO Offline
          OyczE @m5stack
          @m5stack indeed it was two tabs !
          Let me check this, thx for a hint.
            tnkmasayuki
            I can't stop the sound.
            UIFlow1.8.0 + M5StickC Plus
              stefanj9
              Wher can I find version 1.8.0?
              • OyczEO Offline
                OyczE @stefanj9
                • OyczEO Offline
                  OyczE @m5stack
                  @m5stack hmm no luck one tab and still error
                  but ... its just bug me so after listing all modules on AtomDUT its turn on you have made a typo in the from base.DTU_LoRAWAN should be base/DTU_LoRaWAN
                  from base.DTU_LoRAWAN import DTU_LoRAWAN
                  into
                  from base.DTU_LoRaWAN import DTU_LoRaWAN
                    plusulli
                    In the Remote+ documentation for the slider it says "click the gear button on the block to add a variable before use" But there is no gear button.
                    • m5stackM Offline
                      m5stack @plusulli
                      @plusulli sorry. that is a mistake. draw the slider to the preview box. workspace will auto create print block and variable
                      • m5stackM Offline
                        m5stack @OyczE
                        @mati I think the module name is from base.DTU_LoRaWAN import DTU_LoRaWAN......a is lowercase
                        • OyczEO Offline
                          OyczE @m5stack
                          @m5stack said in UIFlow 1.8.0:
                          This is a problem in the UiFlow, after importing lorawan init in the code we have LoRAWAN.
                          And what a supprise its fixed now ;)
                          Day ago was
                          what a nice silent fix =]
                            plusulli
                            in the german version of UIflow Remote+ the slider function is faulty in the english version it is ok i searched for a long time until i found it0_1626729513974_slider.jpg
