    Load images on M5Paper in UIFlow
    12 Posts 7 Posters 17.8k Views
    • fr3ndF Offline
      fr3nd
      I'm trying to load images in a M5Paper unit using uiflow with no success. I've tried several formats (png, bmp, jpg) and different options when saving, but I always get the same result...
      I'm uploading the image in the device file manager, and then after adding the image at the position where I want it, I add the following blocks:
      • Set screen background color
      • Set image0 to image.bmp (to the right name of the image file)
      • Show image0
      • Set screen show
      But When running the program, I get an exclamation mark at the top of the screen.
      Am I doing anything wrong? Is this feature actually working?
        Hello @fr3nd
        have you tried to display the default.jpg? Does that work?
        Using UIFlow 1.8.7 (https://flow.m5stack.com) these are the steps which worked for me:
        • drag image icon onto screen (e.g. image0)
        • block set screen show
        fr3ndF 1 Reply Last reply Reply Quote 0
        • fr3ndF Offline
          fr3nd @felmue
          Hi @felmue
          This works with the default image default.png, but once I upload a different one it shows the exclamation mark symbol.
          I've tried with different formats and options when saving, but I haven't found a combination that works. Is there any documentation on the requirements of the images? Has anyone had any success using custom images in m5paper in uiflow?
            Hello @fr3nd
            sorry, I don't know of any documentation on the requirements of the images.
            • fr3ndF Offline
              fr3nd
              For the record, I was finally able to generate images that load properly with the following ImageMagick command:
              convert image.png -colorspace RGB -depth 8 -colors 16 PNG8:exported/image.png
                ajb2k3 @fr3nd
                @fr3nd I was just about to say that it is an issue with the way the image is saved.
                I started making a document here :https://github.com/Ajb2k3/UIFlowHandbook/blob/master/En-Coreink-V2.pdf
                  doragasu
                  This is a bit late, but today I was trying to display images in M5Stack Fire module, and had the same problem. After a bit of trial and error, I discovered that if the PNG file names are long, this error will trigger. And it is not easy to guess that the long file name caused it!
                    This is a limit of the filesystem formatting.
                    • 7 Offline
                      7ames
                      I know this is an older thread but it really saved me! I downloaded GIMP (latest version is currently 2.10.34) and by exporting a PNG, Turning all checks off and compression level to 9 (max) and then pixelformat to 8bpc RGB. With a small filename the image will appear in the UI Flow workspace and on the M5 stick C Plus.
                      I couldnt get Photoshop, Aseprite and even Paint to get anything in UI flow. But GIMP worked just fine.
                      Hope this helps someone else down the road.
                        ajb2k3 @7ames
                        @7ames I have used GIMP since 1999 and used it in my guide document. Glad you worked it out.
                        • X Offline
                          Xiong_M5Stack @fr3nd
                          @fr3nd the picture must be less than 50kb
                            mtylerjr
                            I just got my M5Paper today, so this is very timely info for me, thanks!
