    UIFlow 1.8.6
    12 Posts 7 Posters 23.6k Views 1 Watching
      plusulli
      I would be happy if someone could explain to me how this would work with REMOTE+ and chart data either I do not get it or it does not work
      • m5stackM Offline
        we will update the tutorial as soon as possible
          I2C bus error when trying to use the Colour LCD unit on core 2
          • OyczEO Offline
            OyczE
            LCD color vs Atom lite
            File "flow/m5cloud.py", line 82, in _exec_fun
            File "<string>", line 20, in <module>
            File "units/_lcd.py", line 128, in fill
            AttributeError: 'Lcd' object has no attribute 'frame_buf'
            File "<string>", line 22, in <module>
            File "units/_lcd.py", line 169, in show_on
            File "i2c_bus.py", line 101, in write_mem_list
            MemoryError: memory allocation failed, allocating 64800 bytes
            • OyczEO Offline
              OyczE @m5stack
              @m5stack said in UIFlow 1.8.6:
              in my case all is working fine on core2 LCD module is connected over PortA
                ajb2k3 @OyczE
                @mati said in UIFlow 1.8.6:
                Have you updated the firmware on the colour lcd?
                I get the framebuf error if I don't add the init screen block
                • OyczEO Offline
                  OyczE @ajb2k3
                  @ajb2k3 said in UIFlow 1.8.6:
                  Nope, just out of the box and go. First try with Atom lite fail but on core2 and init in the setup all looks legit.
                  PhuturistP 1 Reply Last reply Reply Quote 0
                    Soong
                    LCD firmware update and device tested with M5StickC, ATOM, Stamp... From Arduino it works fine but from UIFlow no way.
                    Error from M5StickC plus is "LCD object has no attribute frame_buf
                    • PhuturistP Offline
                      Phuturist @OyczE
                      Could you post your working UIFlow?
                      I have the same issue, gives me the error "'Lcd' object has no attribute 'frame_buf'".
                        Hello @Phuturist
                        using UIFlow 1.9.0 works for me (well kind of). With M5Core2 I can use the whole LCD unit screen (eg. 135 x 240). However with M5Atom (or M5StickCPlus) I can only use part of it, else there is an out of memory error. Here is what works for me with M5Atom.
                          Phuturist @felmue
                          @felmue said in UIFlow 1.8.6:
                          Hello @Phuturist
                          Thanx Felix, it's indeed now working for a small partion of the screen when connected to my M5StickC Plus. Trying to set it to it's actual size indeed results in a memory allocation error. I had seen that one before as well but didnt think it was related to the screen size. If anyone knows how to fix the memory allocation error, please let me know.
