    new m5stack: Failed to write to target RAM (result was 01070000)
    22 Posts 13 Posters 70.5k Views 2 Watching
      Mackone @ajb2k3
      Same thing is happening to me:
      Start Burn
      --chip esp32 --port /dev/tty.usbmodem53190095701 --baud 1500000 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x1000 /Applications/M5Burner.app/Contents/Resources/packages/fw/core/Core2_Tools-v1.0.0.bin
      esptool.py v2.5.0
      Serial port /dev/tty.usbmodem53190095701
      Connecting...
      Chip is ESP32D0WDQ6 (revision 1)
      Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse
      MAC: 08:3a:f2:66:b7:70
      Uploading stub...
      A fatal error occurred: Failed to write to target RAM (result was 01070000)
      Burn Failed
      Fighting for over 10 hours.. I'm dying here..
        Mackone @darul75
        @darul75
        Same here - Have You found any solution?
        • E Offline
          erich
          This was a known issue with Big Sur (something related to the python and / or serial port implementation in Big Sur.
          I did contact M5Stack support but no solution has ever been found.
          I gave up and reverted back to Catalina and it worked fine again.
          Now I just installed the latest Monterey but haven't tested the Core2 yet.
          In the meantime I was also using a windows computer....
            Mackone @erich
            @erich I'm on Mojave 10.14 and problem still exists :/
              I’m actually getting it with Catalina
                slugs
                Has anyone managed to get the core 2 to work with an M1 mac? I think that you do not need the driver for the m1? With a m5stick C it works fine, but not with the core 2
                • ExieE Offline
                  Exie
                  I have the same issue when I use the M5Stack ESP32 Downloader.
                  However when I use a simple M5Stack Atom Matrix, its works fine.
                  I am on OSX Big Sir.
                  I feel like the issue is related to the CH9102 chip on the ESP32 Downloader where the Atom has the CP2104 I think.
                  This theory is supported by this article here:
                  https://blog.squix.org/2021/08/ch9102-driver-issues-failed-to-write-to-target-ram.html
                  Confirmed, installing the driver from this thread here worked for me
                  https://github.com/Xinyuan-LilyGO/LilyGo-T-Call-SIM800/issues/139
                  • E Offline
                    erich @Exie
                    @exie said in new m5stack: Failed to write to target RAM (result was 01070000):
                    I guess you're right as I noticed on banggood/ aliexpress some products using this CH9102 chip are tagged as not Mac compatible.
                    • L Offline
                      labixiaoxin8888 @Mackone
                      @mackone try connecting the downloader's 3V3 to Stamp Pico's 5V
                        parahooner
                        I found a solution that works on Montery :-)
                        Make sure you follow the PDF instructions, this works M1 Mac M5 Epaper
                        http://www.wch.cn/downloads/CH34XSER_MAC_ZIP.html
                        B 1 Reply Last reply Reply Quote 2
                        • B Offline
                          Bludotz @parahooner
                          @parahooner Very many thanks for posting this, it completely resolved the problem.
                          • drjakobD Offline
                            drjakob
                            I still have the same problem with 5 new M5Fire on Big Sur. Two older ones burned succesful.
                              ajb2k3 @drjakob
                              @drjakob Check which USB driver is in the new cores as the driver chip was changed due to the part shortage.
