    new m5stack: Failed to write to target RAM (result was 01070000)
    22 Posts 13 Posters 70.5k Views 2 Watching
      Mackone @darul75
      @darul75
      Same here - Have You found any solution?
      • E Offline
        erich
        This was a known issue with Big Sur (something related to the python and / or serial port implementation in Big Sur.
        I did contact M5Stack support but no solution has ever been found.
        I gave up and reverted back to Catalina and it worked fine again.
        Now I just installed the latest Monterey but haven't tested the Core2 yet.
        In the meantime I was also using a windows computer....
          Mackone @erich
          @erich I'm on Mojave 10.14 and problem still exists :/
            I’m actually getting it with Catalina
              slugs
              Has anyone managed to get the core 2 to work with an M1 mac? I think that you do not need the driver for the m1? With a m5stick C it works fine, but not with the core 2
              • ExieE Offline
                Exie
                I have the same issue when I use the M5Stack ESP32 Downloader.
                However when I use a simple M5Stack Atom Matrix, its works fine.
                I am on OSX Big Sir.
                I feel like the issue is related to the CH9102 chip on the ESP32 Downloader where the Atom has the CP2104 I think.
                This theory is supported by this article here:
                https://blog.squix.org/2021/08/ch9102-driver-issues-failed-to-write-to-target-ram.html
                Confirmed, installing the driver from this thread here worked for me
                https://github.com/Xinyuan-LilyGO/LilyGo-T-Call-SIM800/issues/139
                • E Offline
                  erich @Exie
                  @exie said in new m5stack: Failed to write to target RAM (result was 01070000):
                  I guess you're right as I noticed on banggood/ aliexpress some products using this CH9102 chip are tagged as not Mac compatible.
                  • L Offline
                    labixiaoxin8888 @Mackone
                    @mackone try connecting the downloader's 3V3 to Stamp Pico's 5V
                      parahooner
                      I found a solution that works on Montery :-)
                      Make sure you follow the PDF instructions, this works M1 Mac M5 Epaper
                      http://www.wch.cn/downloads/CH34XSER_MAC_ZIP.html
                      B 1 Reply Last reply Reply Quote 2
                      • B Offline
                        Bludotz @parahooner
                        @parahooner Very many thanks for posting this, it completely resolved the problem.
                        • drjakobD Offline
                          drjakob
                          I still have the same problem with 5 new M5Fire on Big Sur. Two older ones burned succesful.
                            ajb2k3 @drjakob
                            @drjakob Check which USB driver is in the new cores as the driver chip was changed due to the part shortage.
