    Core2 does not start after replacing CORE2 cover
    9 Posts 2 Posters 10.4k Views 1 Watching
      Kombistack
      I have been making and using programs with the CORE2 cover off of my Core2 controller, so I can access the GPIO pins. Now when I replaced the CORE2 cover I cannot power on/start my Core 2 controller. Each time that I remove the CORE2 cover, again I can power on the controller. Every time I put the cover back on it wont power on.
      How do I overcome this please??
      • felmueF Online
        Hello @Kombistack
        more information needed.
        • with the CORE2 cover removed, how is M5Core2 powered? Battery or USB?
        • with the CORE2 cover replaced, how is M5Core2 powered? Battery or USB?
          Kombistack
          Hi
          Both times I am using battery
          • felmueF Online
            Hello @Kombistack
            ok, good, so it's not a flat battery. What exactly do you mean by CORE2 cover? I assume you mean the small board labelled CORE2 holding the microphone and IMU chip, yes? When you replace it, do you have the grey plastic cover (which holds the battery) installed as well? I ask because w/o it I guess it is possible to mis-align the CORE2 board. Also have you pushed in the CORE2 board enough? I could imagine that with only some pins making contact wired things (like not booting) could happen.
              Kombistack
              Hi Felix,
              Yes by ‘cover’ I do mean the small board labelled CORE2 holding the microphone and IMU chip. I have pressed this cover fully in so I don’t think it’s a problem with pins not making good contact
              I haven’t disassembled the Core 2 any more than removing this cover so I haven’t accessed the battery and the grey cover holding the battery in.
              I have updated the Core2 firmware today to v1.10.1 and this hasn’t made any difference.
              • felmueF Online
                Hello @Kombistack
                I haven't used the small CORE2 board for some time and when I connected it today my M5Core2 wouldn't start up either. I then removed the board again and only pushed it in slightly - M5Core2 started up ok but as soon as I pushed the board a bit harder M5Core2 stopped working.
                I then had a closer look and I think what's happening is that some contacts of the CORE2 board touch the metal housing of either the vibrating motor and / or the metal back plate of the speaker. Isolating both metal parts with some tape helped. Now I can push in the CORE2 board securely and M5Core2 still works.
                  Kombistack
                  Hi Felix,
                  PROBLEM SOLVED!
                  You are right. When I removed the CORE2 cover and replaced it with only slight pressure the controller boots up.
                  SO the trick is not to push too hard and push the cover too far in, or as you say isolate the metal parts with tape.
                  Thank you for problem solving this for me and probably for others who have the same issue.
                  Cheers
                    Kombistack
                    What really caused the issue!
                    Further to my last post I have found that the real issue whereby my Core2 cover caused the Core2 to shut down when the cover was pushed back in place was due to damage to the Core2 cover.
                    I obviously had damaged some of the components of the accelerometer when I removed the Core2 cover with a screwdriver!
                    I hope I can purchase just a replacement cover.
                    Something to be aware of when removing the Core2 cover.
                    • felmueF Online
                      Hello @Kombistack
                      from what I can tell the damage isn't that severe. According to the schematic those two components are capacitors. I don't think they are critical for the overall functionality of the M5Core2, they might have an influence on the performance of the IMU though.
                      That said, you should be able to resolder those with a small soldering iron. Or find someone who can fix it for you.
                      I don't know if this board can be purchased separately as spare part. Have you checked with M5Stack support?
