    M5StickC-Plus Buzzer not working
    10 Posts 7 Posters 17.0k Views 1 Watching
    • _ Offline
      _Rob
      I have several M5StickC-Plus's but I cannot seem to get the buzzer to work. The factory test has code in it to use the buzzer on button press but it does not seem to work. Can someone point me to code to make this buzzer work?
      Thanks.
      • m5stackM Online
        try to use UIFlow for the test
        • _ Offline
          _Rob
          I have not used uiflow before but tried to get it running to test this. I was unable to get uiflow working on my windows 10 system.
          Please provide an arduino C example.
          • W Offline
            Wilfried
            On my two M5StickC-Plus the Buzzer is also not working. Please provide an Arduino example.
            M W 2 Replies Last reply Reply Quote 0
              Rob 0
              The default volume is very low and probably only audible to young bats :)
                macsbug @Wilfried
                Hello @wilfried
                Arduino example:
                https://101010.fun/iot/m5stickc-plus-firststep.html
                • teastainT Offline
                  teastain @macsbug
                  @macsbug Still very faint!
                  Not useable!
                  • W Offline
                    wsanders
                    I'm not sure what is connected to it, probably some tiny piezo speaker, but pin G2 is the "buzzer" pin.
                    There is a way to set up PWM on a pin at a desired frequency. Also, sometimes these speakers are resonant, so much louder at a particular frequency.
                    Example using the API, below:
                    • W Offline
                      wsanders
                      Using //https://101010.fun/iot/m5stickc-plus-firststep.html
                      for inspiration, we can upload this program:
                      #include <M5StickCPlus.h>
                      M5.Lcd.setTextSize(3);
                      M5.Lcd.setRotation(3);
                      M5.Lcd.setTextColor(TFT_ORANGE);
                      M5.update();
                      soundTest();
                      void soundTest() {
                      for (int tone=100; tone < 4000; tone=tone+50) {
                      M5.Lcd.fillScreen(BLACK);
                      M5.Lcd.setCursor(80, 50);
                      M5.Lcd.printf("%d", tone);
                      M5.Beep.tone(tone);
                      M5.Beep.update();
                      delay(200);
                      According to my ears there is a definite peak about 2500 Hz, with frequencies under 250 Hz and over 3000 not audible. Your ears may vary .....
                      • W Offline
                        Wilfried @Wilfried
                        @wilfried Ok, that workrd. ThankYou
