ENV3 unit maybe not connect.
Hi All, I am not able to pinpoint my mistake copied example blocks, I hope someone can help me with this. I am not able to upload the error message to this forum, but it says 'ENV3 unit maybe not connect.' These is what I did:-
connect to flow.m5stack.com
click on the '+' icon from the left panel;
selected ENV3 HAT from a HAT selections screen;
click UNIT, ENV, Read example, drag the example to form a functional block
click 'Run' and got the err msg mentions above. Thanks for your help.
@dididada
Unit ENVI, II, III are substantially different as well as the distinction between a Hat ENV and a Unit ENV.
https://docs.m5stack.com/en/hat/hat_envIII
https://docs.m5stack.com/en/unit/envIII -
@teastain , Thanks for the info. I am at this for days, have been back and fort with supports@m5, this makes me feel terrible stupid for not able to get this HAT to work. I was expecting that by copying the example blocks, I would be able to get it to work. (very new to this.) There isn't any other options to select, except ENV under UNIT. Also, I have flip to micropython to cut/paste the code , then ran it on Thonny, it failed there, too; this also happen under Arduino (cut/paste) M5 example code for Arduino. I float the idea to the support@m5 that the HAT might be faulty but nothing from support@m5 on this defective HAT issue. I failed to mention that this is about the m5stickc plus. I hope the support@m5 will see this and come up with something to help me out. Or, anybody else out there that is able to help. Thanks again.
Resolved, the part that generated 'env3 unit maybe not connect' , I use the HAT (ENV) this time and don't get the error message. This, I still not sure that I blindly got it as I supposed to. Well, go on learning. Thanks.
