    AtomDTU NB-IoT
    32 Posts 2 Posters 36.8k Views
      Felix22
      thanks
      The return is
      b'AT\r\r\nOK\r\n'
        Hello @Felix22
        ok, his means your modem is alive and responding.
        Now, please try the following commands (which are the same as are used in Init NB-IoT DTU) block, but we can see the responses of the modem:
        You should get something like:
        b'\r\nOK\r\n'
        b'\r\nOK\r\n'
        b'\r\nOK\r\n'
        b'\r\n+CPIN: READY\r\n\r\nOK\r\n'
        b'\r\n+CGCONTRDP: 1,5,"<YourAPN>","10.100.100.100.255.255.255.0"\r\n\r\nOK\r\n'
          Felix22
          Yesterday i have made the similar with Arduino-C-Code and become as Response the carrier Code 28801 = Swisscom-Network but no response in q.beyond-Control-Panel...
          I have tested with a complete new AtomDTU. Flash with v1.13.2
          I think, no response :-((
            Hello @Felix22
            I just read in the q.beyond FAQ says that the SIM card needs to be activated.
            I assume you did that already?
              Felix22
              Yes, I have do it. She is activated.
              The connection from 17.2.24 comes from a old iPhone
                Hello @Felix22
                ok, let's see what providers your modem can see.
                Note: the last AT command AT+COPS=? can take a couple of minutes as it has to scan through all bands. (in my case it took about 3 minutes.)
                Expected output:
                b'\r\nOK\r\n'
                b'\r\nOK\r\n'
                b'\r\n+COPS: 0,2,"22801",9\r\n\r\nOK\r\n'
                None
                b'\r\n+COPS: (1,"SWISS GSM","SWISS","22801",9),(1,"sunrise","sunrise","22802",9),,(0-4),(0-2)\r\n\r\nOK\r\n'
                  Felix22
                    Hello @Felix22
                    ok, so it seem that the modem is registered with Swisscom, but doesn't get an IP address since AT+COPS? succeeds, but AT+CGCONTRDP fails.
                    At this point I am not sure what might be the issue. Is there anything in the q.beyond portal, like a log showing some error?
                    Also since you used your iPhone with that SIM card before there might be some kind of security check not accepting a connection from a different device. On the q.beyond portal, is there a way to reset / clear the data from the previous connection?
                      Felix22
                      Interesting, this is the response from the DigitalRepublic-SIM-Card how has no NarrowBand.
                      He see the Network also...
                      Now, ih have deactivated and new activated the SIM.
                      Now its a "3" = "Operator forbidden" (?) (Swisscom)
                      and
                      1 for sunrise
                        Hello @Felix22
                        hmm, strange. Do you know which roaming partner (Swisscom and/or Sunrise) q.beyond has in Switzerland for NB-IoT? Maybe worth checking with q.beyond support.
                          Felix22
                          Many thanks.
                          I will write to the support from q.beyond.
                          If the connection will go on. What are the Code for an MQTT connection ?
                          If i become an IP-Address, can i use the "normal" MQTT Blockly ??
                          Regards,
                            Hello @Felix22
                            please refer to the SIM7020 documentation for MQTT commands. You can find the PDFs here - section Related Link.
                            As soon as the modem gets an IP address the last AT command AT+CGCONTRDP sent by Init NB-IoT DTU block should succeed and then you can use all the other MQTT blocks.
                              Felix22
                              a.beyond say, she works in Switzerland with Swisscom NB.
                              How can I explicit connect to Swisscom (AT-Command) ?
                                Hello @Felix22
                                AT+COPS=1,2,"22801"
                                  Felix22
                                  b'AT+CSQ\r\r\n+CSQ: 18,0\r\n\r\nOK\r\n'
                                  men, i have a signal ?
                                  b'AT+CSTT="iotsim.melita.io","",""\r\r\nOK\r\n'
                                  b'AT+CSTT?\r\r\n+CSTT: "iotsim.melita.io","",""\r\n\r\nOK\r\n'
                                  APN is set correct ?
                                  b'AT+CGREG?\r\r\n+CGREG: 0,5\r\n\r\nOK\r\n'
                                  Registered ?
                                  b'AT+COPS: 1,2,"22801"\r\r\nERROR\r\n'
                                  b'AT+COPS?\r\r\n+COPS: 0,2,"22801",9\r\n\r\nOK\r\n'
                                  b'AT+CGACT?\r\r\n+CGACT: 1,0\r\n\r\nOK\r\n'
                                  If i have a connection, do i become an ip-address ?
                                  with the command AT+CIFSR
                                    Hello @Felix22
                                    it is my understanding that AT+CIFSR returns the local IP address in a TCP or UDP connection. (It's an AT command for compatibility with SIM800.)
                                    See PDF document SIM7020 Series_TCPIP_Application Note_V1.04 - 6.2 TCP Client Connection. You'll find the link to the PDF here.
                                    The way I use to set the APN is described in the same TCP/IP PDF - 3.2 APN Manual Configuration.
                                      Felix22
                                      Result:
                                      b'\r\nOK\r\n'
                                      b'\r\nOK\r\n'
                                      b'\r\nOK\r\n'
                                      b'\r\nOK\r\n'
                                      b'\r\nOK\r\n\r\n+CPIN: READY\r\n'
                                      b'\r\n+CGREG: 0,5\r\n\r\nOK\r\n'
                                      b'\r\n+CGCONTRDP: 1,5,"iotsim.melita.io","10.xx.xx.xx.255.255.255.0",,"212.xx.xx.xx","212.xx.xx.xx",,,,,1500\r\n\r\nOK\r\n'
                                      Im a big step wider... now, i have become my ip address... :-)
                                      Now i think... MQTT, next step.
                                        Felix22
                                        Juhuuuu !!
                                        It works !
                                        More Information and the solution will follow...
                                        @felmue : many thanks
                                          Hello @Felix22
                                          I am happy to hear you got it working.
                                            Felix22
                                            now, i have a new problem.
                                            The mqtt broker test.mosquitto.test is working with my Blockly but my own Broker on my Server at home in a Docker container is not available from AtomDTU. But with a Internet Test Tool, it is working ( https://testclient-cloud.mqtt.cool/ )
                                            I see no difference...
                                            The orange part is working and the tree other is not working
                                            • Domainname
                                            • IP-Address
                                            • Dyndns
                                              not working...
                                              test.mosquitto.org is working fine.
