    AtomDTU NB-IoT
    32 Posts 2 Posters 36.6k Views
      Hello @Felix22
      I just read in the q.beyond FAQ says that the SIM card needs to be activated.
      I assume you did that already?
        Felix22
        Yes, I have do it. She is activated.
        The connection from 17.2.24 comes from a old iPhone
          Hello @Felix22
          ok, let's see what providers your modem can see.
          Note: the last AT command AT+COPS=? can take a couple of minutes as it has to scan through all bands. (in my case it took about 3 minutes.)
          Expected output:
          b'\r\nOK\r\n'
          b'\r\nOK\r\n'
          b'\r\n+COPS: 0,2,"22801",9\r\n\r\nOK\r\n'
          None
          b'\r\n+COPS: (1,"SWISS GSM","SWISS","22801",9),(1,"sunrise","sunrise","22802",9),,(0-4),(0-2)\r\n\r\nOK\r\n'
            Felix22
              Hello @Felix22
              ok, so it seem that the modem is registered with Swisscom, but doesn't get an IP address since AT+COPS? succeeds, but AT+CGCONTRDP fails.
              At this point I am not sure what might be the issue. Is there anything in the q.beyond portal, like a log showing some error?
              Also since you used your iPhone with that SIM card before there might be some kind of security check not accepting a connection from a different device. On the q.beyond portal, is there a way to reset / clear the data from the previous connection?
                Felix22
                Interesting, this is the response from the DigitalRepublic-SIM-Card how has no NarrowBand.
                He see the Network also...
                Now, ih have deactivated and new activated the SIM.
                Now its a "3" = "Operator forbidden" (?) (Swisscom)
                and
                1 for sunrise
                  Hello @Felix22
                  hmm, strange. Do you know which roaming partner (Swisscom and/or Sunrise) q.beyond has in Switzerland for NB-IoT? Maybe worth checking with q.beyond support.
                    Felix22
                    Many thanks.
                    I will write to the support from q.beyond.
                    If the connection will go on. What are the Code for an MQTT connection ?
                    If i become an IP-Address, can i use the "normal" MQTT Blockly ??
                    Regards,
                      Hello @Felix22
                      please refer to the SIM7020 documentation for MQTT commands. You can find the PDFs here - section Related Link.
                      As soon as the modem gets an IP address the last AT command AT+CGCONTRDP sent by Init NB-IoT DTU block should succeed and then you can use all the other MQTT blocks.
                        Felix22
                        a.beyond say, she works in Switzerland with Swisscom NB.
                        How can I explicit connect to Swisscom (AT-Command) ?
                          Hello @Felix22
                          AT+COPS=1,2,"22801"
                            Felix22
                            b'AT+CSQ\r\r\n+CSQ: 18,0\r\n\r\nOK\r\n'
                            men, i have a signal ?
                            b'AT+CSTT="iotsim.melita.io","",""\r\r\nOK\r\n'
                            b'AT+CSTT?\r\r\n+CSTT: "iotsim.melita.io","",""\r\n\r\nOK\r\n'
                            APN is set correct ?
                            b'AT+CGREG?\r\r\n+CGREG: 0,5\r\n\r\nOK\r\n'
                            Registered ?
                            b'AT+COPS: 1,2,"22801"\r\r\nERROR\r\n'
                            b'AT+COPS?\r\r\n+COPS: 0,2,"22801",9\r\n\r\nOK\r\n'
                            b'AT+CGACT?\r\r\n+CGACT: 1,0\r\n\r\nOK\r\n'
                            If i have a connection, do i become an ip-address ?
                            with the command AT+CIFSR
                              Hello @Felix22
                              it is my understanding that AT+CIFSR returns the local IP address in a TCP or UDP connection. (It's an AT command for compatibility with SIM800.)
                              See PDF document SIM7020 Series_TCPIP_Application Note_V1.04 - 6.2 TCP Client Connection. You'll find the link to the PDF here.
                              The way I use to set the APN is described in the same TCP/IP PDF - 3.2 APN Manual Configuration.
                                Felix22
                                Result:
                                b'\r\nOK\r\n'
                                b'\r\nOK\r\n'
                                b'\r\nOK\r\n'
                                b'\r\nOK\r\n'
                                b'\r\nOK\r\n\r\n+CPIN: READY\r\n'
                                b'\r\n+CGREG: 0,5\r\n\r\nOK\r\n'
                                b'\r\n+CGCONTRDP: 1,5,"iotsim.melita.io","10.xx.xx.xx.255.255.255.0",,"212.xx.xx.xx","212.xx.xx.xx",,,,,1500\r\n\r\nOK\r\n'
                                Im a big step wider... now, i have become my ip address... :-)
                                Now i think... MQTT, next step.
                                  Felix22
                                  Juhuuuu !!
                                  It works !
                                  More Information and the solution will follow...
                                  @felmue : many thanks
                                    Hello @Felix22
                                    I am happy to hear you got it working.
                                      Felix22
                                      now, i have a new problem.
                                      The mqtt broker test.mosquitto.test is working with my Blockly but my own Broker on my Server at home in a Docker container is not available from AtomDTU. But with a Internet Test Tool, it is working ( https://testclient-cloud.mqtt.cool/ )
                                      I see no difference...
                                      The orange part is working and the tree other is not working
                                      • Domainname
                                      • IP-Address
                                      • Dyndns
                                        not working...
                                        test.mosquitto.org is working fine.
                                        Hello @Felix22
                                        hmm, that's a tricky one. Now that your modem gets an IP address; have you tried the official MQTT blocks?
                                          Felix22
                                          you mean the blocks at "Fortgeschritten" / MQTT ?
                                          over there it connects over Wlan/Wifi...
                                          Is there a MQTT-Block how i can say the RX and TX pin ?
                                            Hello @Felix22
                                            no, I meant in UIFlow1 with M5Atom selected. Then it's under Base - DTU - NB-IoT - MQTT. There even is an MQTT example.
