    Force reset M5 stack
    3 Posts 2 Posters 24.9k Views 1 Watching
      keptan
      After inadvertently uploading a sketch that outputs to wrong pin numbers one of our M5 stacks has become un-uploadable. That is whenever it's given power the speaker emits loud continuous buzzing and the hardware won't show up as a serial port.
      Is there anyway to force hardware into an uploadable state and reset.
      Hardware is original M5 stack without 4mb psram
        keptan @keptan
        @keptan
        We managed to fix it
        simply holding down button A and reset button until Arduino ide attempted to connect
        then releasing it and allowing it to upload without a chance for the old code to run
          mylesdebaerdemaeker
          For the m5stack fire you need to follow these steps
          1. Remove all modules, leaving only the host
          2. Then try to lower the baud rate when burning
          3. If there are wires, you can short-circuit G0-GND before powering on the device and then power on again.0_1711007646460_432299571_430472252787300_1867478767739245481_n.jpg
