Arduino & TimerCameraX - webcam examples just don't work
I'm trying to use a TimerCameraX with Arduino, with the latest versions of everything.
Both of the Timer-CAM webcam examples (sta and ap) work for a little while, then become very intermittent, then stop delivering frames altogether.
Are these examples meant to work correctly with the TimerCameraX ? Should I be looking somewhere else for decent examples ?
Thanks,
Richard -
Hello @jarkman
I assume you already have PSRAM enabled in your build, yes?
BTW: Not sure why but changing the frame_size from FRAMESIZE_QVGA to the camera native FRAMESIZE_QXGA helped a lot.
Felix -
@felmue - thanks. I had PSRAM enabled but perhaps not the right partition scheme.
I now have PSRAM enabled and I'm using the default partition scheme ('default 4MB with spiffs...').
I see it
- working with FRAMESIZE_QVGA (320x200)
- working but frequently blocking for several seconds with FRAMESIZE_SVGA (800x600) as in the original sample
- crashing instantly with FRAMESIZE_QXGA (2048x1536)
Any thoughts ?
thanks,
Richard -
