    No GPS unit examples?
    14 Posts 3 Posters 31.4k Views 1 Watching
      what doesn't work?
      • yelloweliseY Offline
        yellowelise
        this is the response:
        $GNRMC,,V,,,,,,,,,,M4E
        $GNVTG,,,,,,,,,M
        2D
        $GNZDA,,,,,,56
        $GPTXT,01,01,01,ANTENNA OPEN
        25
        $GNGGA,,,,,,0,00,25.5,,,,,,64
        $GNGLL,,,,,,V,M
        79
        $GPGSA,A,1,,,,,,,,,,,,,25.5,25.5,25.502
        $BDGSA,A,1,,,,,,,,,,,,,25.5,25.5,25.5
        13
        $GPGSV,1,1,0079
        $BDGSV,1,1,00
        68
        $GNVTG,,,,,,,,,M
        2D
        $GNZDA,,,,,,56
        25
        $GNGLL,,,,,,V,M
        79
        13
        $GPGSV,1,1,0079
        $BDGSV,1,1,00
        68
        $GNVTG,,,,,,,,,M
        2D
        $GNZDA,,,,,,56
        25
          yellowelise
          https://github.com/yellowelise/M5Stack-GPS-Unit
          this code works!
          config:
          M5Stack Fire with PSRAM DISABLED (g17/g16 conflict)
          AT6558 GPS Unit attached at PORT C
          • m5-docsM Offline
            m5-docs @yellowelise
            @yellowelise
            Hi, I guest you are indoors and GPS Unit Example prints raw data needed to be transfer to readable data.
            M5Stack documentation URL
            https://docs.m5stack.com
            • m5-docsM Offline
              m5-docs @ajb2k3
              @ajb2k3 Guy, Thanks your reply!
                yellowelise
                I use tinygps++,
                how can I change gps serial boud rate?
                and how can I use 10hz sample rate?
                m5-docsM 2 Replies Last reply Reply Quote 0
                • m5-docsM Offline
                  @yellowelise
                  I think you need to reinitialize GPS Unit for changing baudrate.
                  • m5-docsM Offline
                    @yellowelise
                    Write a reinit() function for reinitialization.
                      yellowelise
                      @watson
                      No baud in HardwareSerial but Baud in GPS module config, what is the correct NMEA string to config Serial Baud rate communication from GPS to HOST and what is the correct sentence to ser 10hz frequency?
                      es. $GPTXT.......
                      • m5-docsM Offline
                        @yellowelise
                        Hope those will help you.
                        Comes from http://www.icofchina.com/d/file/xiazai/2018-05-23/2b29a8da746eec0ef1dcd9deae895298.zip
                          yellowelise
                          GOOOOOOD!!!
                          Works fine for me!
                          tnx very much!
