    No GPS unit examples?
    14 Posts 3 Posters 30.4k Views 1 Watching
    • yelloweliseY Offline
      yellowelise
      this is the response:
      $GNRMC,,V,,,,,,,,,,M4E
      $GNVTG,,,,,,,,,M
      2D
      $GNZDA,,,,,,56
      $GPTXT,01,01,01,ANTENNA OPEN
      25
      $GNGGA,,,,,,0,00,25.5,,,,,,64
      $GNGLL,,,,,,V,M
      79
      $GPGSA,A,1,,,,,,,,,,,,,25.5,25.5,25.502
      $BDGSA,A,1,,,,,,,,,,,,,25.5,25.5,25.5
      13
      $GPGSV,1,1,0079
      $BDGSV,1,1,00
      68
      $GNVTG,,,,,,,,,M
      2D
      $GNZDA,,,,,,56
      25
      $GNGLL,,,,,,V,M
      79
      13
      $GPGSV,1,1,0079
      $BDGSV,1,1,00
      68
      $GNVTG,,,,,,,,,M
      2D
      $GNZDA,,,,,,56
      25
        yellowelise
        https://github.com/yellowelise/M5Stack-GPS-Unit
        this code works!
        config:
        M5Stack Fire with PSRAM DISABLED (g17/g16 conflict)
        AT6558 GPS Unit attached at PORT C
        • m5-docsM Offline
          m5-docs @yellowelise
          @yellowelise
          Hi, I guest you are indoors and GPS Unit Example prints raw data needed to be transfer to readable data.
          M5Stack documentation URL
          https://docs.m5stack.com
          • m5-docsM Offline
            m5-docs @ajb2k3
            @ajb2k3 Guy, Thanks your reply!
              yellowelise
              I use tinygps++,
              how can I change gps serial boud rate?
              and how can I use 10hz sample rate?
              m5-docsM 2 Replies Last reply Reply Quote 0
              • m5-docsM Offline
                @yellowelise
                I think you need to reinitialize GPS Unit for changing baudrate.
                • m5-docsM Offline
                  @yellowelise
                  Write a reinit() function for reinitialization.
                    yellowelise
                    @watson
                    No baud in HardwareSerial but Baud in GPS module config, what is the correct NMEA string to config Serial Baud rate communication from GPS to HOST and what is the correct sentence to ser 10hz frequency?
                    es. $GPTXT.......
                    • m5-docsM Offline
                      @yellowelise
                      Hope those will help you.
                      Comes from http://www.icofchina.com/d/file/xiazai/2018-05-23/2b29a8da746eec0ef1dcd9deae895298.zip
                        yellowelise
                        GOOOOOOD!!!
                        Works fine for me!
                        tnx very much!
