    cardputer stuck on develop
    24 Posts 8 Posters 24.7k Views 2 Watching
      Does windows hardware manager or what ever its called show an error with the ports?
      • RuelvilloR Offline
        Ruelvillo
        When in doubt, G0 and RST it out, hold G0 and tap RST and then let go of G0.
        • W Offline
          wilsoreal
          has anyone found a solution, i am having the same problem
            @wilsoreal said in cardputer stuck on develop:
            Have you watched the video I linked to above?
            • W Offline
              wilsoreal @ajb2k3
              @ajb2k3 yea but still cant erase my sd and when i try to navigate anything in UI flow 2 it just doesnt work
                ROLF_STEINER
                hi guys!!! same thing here too....
                I used multiple cables (no result)
                I updated softwares like a collector in a bunch of them...(same results)...
                im absolutely lost....
                so if someone see the light please share the trick...0_1715919681849_49fe5e9d-cbe7-4bf7-a20b-41c468144631-Captura de pantalla 2024-05-17 a las 00.16.41.png Captura de pantalla 2024-05-17 a las 00.16.41
                Captura de pantalla 2024-05-17 a las 00.16.54
                Captura de pantalla 2024-05-17 a las 00.17.05
                Captura de pantalla 2024-05-17 a las 00.19.24
                  ROLF_STEINER @ROLF_STEINER
                  @rolf_steiner 0_1715919754111_e65ec64d-476a-4348-b3ba-5aa2e8278b4b-Captura de pantalla 2024-05-17 a las 00.16.41.png Captura de pantalla 2024-05-17 a las 00.16.41
                  0_1715919776087_d7f2a03d-e560-4cd2-8112-b037947185cb-Captura de pantalla 2024-05-17 a las 00.16.54.png Captura de pantalla 2024-05-17 a las 00.16.54
                  0_1715919798187_0042aa19-4ca4-42d3-9ac9-49e45cb656d8-Captura de pantalla 2024-05-17 a las 00.17.05.png Captura de pantalla 2024-05-17 a las 00.17.05
                  0_1715919817648_d392fe34-7bc3-41fa-a53c-753f7b2bfd19-Captura de pantalla 2024-05-17 a las 00.19.24.png Captura de pantalla 2024-05-17 a las 00.19.24
                    Have you installed ESP-IDF?
                      ROLF_STEINER @ajb2k3
                      @ajb2k3 sure mate, after all, I redo all my steps and following the youtube video finally works.
                      many thanks and tons of likes!!
                        mnhj @ToxicAvenger
                        @ToxicAvenger hi i got a new core s3 and was not aware of this boot mode and the error was also occoring to me but on sync screen but on the core s3 to fix it i have to hold the reset button until ther green light turns on then only it started to upload new uiflow so for the cardputer it might be the same problem and also try using a diffrent usb cable.I was using wifi upload and it crashed during sync
                        software info and hardware
                        board : m5stack core s3
                        MCU : esp32s3 extenza lx7
                        uiflow vertion : 2.0.7
                        arduino ver : 2.1.0
                        windows 10
                        • E Offline
                          elektron2kim @ROLF_STEINER
                          @ROLF_STEINER
                          M5Stack documented this for each device. "Press G0 while booting...." or similar. Yes, I had problems too.
