    195 Posts 79 Posters 568.9k Views 13 Watching
      chrol @CAT the Tech
      I noticed the THERMAL2Unit name is capitalised wrong in UIFlow 2 web - in the m5stack/unit/init.py it is called "ThermalUnit2" => Import error.
      (Even after doing manual codeblock edit I don't get an import error but other errors - but this should likely be fixed anyway)
      C
        chrol @chrol
        I see that the ThermalUnit2 is now fixed :)
        Next issue -
        • how can I access temperature data buffer and include in REST API or
        • present it on screen (e.g. do I use it as source for an image UI component somehow?)
        Thanks!
        @chrol said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
        C
        • Coopersmith-24601C Offline
          Coopersmith-24601
            Coopersmith-24601
            FEATURE REQUEST!
            It would be extraordinarily helpful for there to be a type of LABEL in UiFlow2 which could fill the screen and word-wrap long text strings.
            • IAMLIUBOI Offline
              IAMLIUBO @Coopersmith-24601
              @Coopersmith-24601 said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
              FEATURE REQUEST!
              Yes. Thanks for suggestion. We will consider this.
                Calvorotas
                I am trying to receive a bytearray via BLE from a server, but I can't get a response.
                By sending a certain bytearray via BLE to the Sbrick device, it returns a response indicating the temperature value. And through another bytearray, the voltage value is returned.
                In App Inventor I get it with these blocks:image-1.png image-2.png
                But in UiFlow 2.0 I can't get it using these blocks:
                What am I doing wrong?
                s it possible that this block will not trigger the server response?
                Perhaps, the mode argument is mode=0 (write-without-response). Or am I mixing up different things?
                I can't get a response from the server with the "When BLE client on notify" block or with the "When BLE client on read complete" block
                I need help, or a lot of help. :)
                Thank you very much.
                • greenleafG Offline
                  greenleaf
                  Feature request:
                  Ability to set headers for Label+ objects. Many APIs required these headers before they respond with proper JSON.
                  Example:
                  curl -H "Accept: application/json" https://icanhazdadjoke.com/
                    Rango
                    I'm using a MiniJoyC with M5stuckC Plus2 and UIFlow 2.1.4.
                    I've read through examples and documentation but I can not get x or y values. They only display 0.
                    Same thing happens in Arduino IDE.
                    I do get values when using UI flow 1, so I know the minijoy is working.
                    Any known issues with the UIf2 libraries?
                    Thanks in advance.
                    • G Offline
                      gbelfor
                      Using: UIFlow 2.1.5, AtomS3, KMeterISOunit
                      From the version history, it appears that the Firmware changed the KMeterISOunit API a couple revs back, but UIFlow is still generating code for the old API. When I do the blockly code and run on my AtomS3, an exception is thrown showing the issue:
                      Code generated (snipit)
                      ...but from the latest API docs, the reading code should be:
                      Note: I did a workaround using the "Execute mpy code" block and writing in the proper API calls, but it would be nicer if the versions matched up.
                      • X Offline
                        xs
                        Are GoPlus2 module not supported in UiFlow2? Do you plan to add support?
                        • X Offline
                          xs @xs
                          @xs Also, Servo2 module isnt sopported
                          • ? Offline
                            A Former User
                            Hello, could you add more RTC blocks to Uiflow2? Like the ones in Uiflow1? I'm a beginner and I wanted to make a simple clock app for the cardputer but for now seems impossible for me without learning to code. Also it would be nice to have all the apps I built in the App.list section of Uiflow2 on my cardputer. Thanks! Screenshot 2024-11-17 194153.png
                            cryptospokC 1 Reply Last reply Reply Quote 1
                            • cryptospokC Offline
                              cryptospok
                              I'm using UIFlow2 on Microsoft Edge and when I try to create a variable with the name of an object that already exists, I get the conflict information and even if I correct it, when I exit the variable creation window, UIFlow2 crashes and I have to reload the page to continue.
                                cryptospok @Guest
                                  riztronic
                                  missing magnetometer scratch code for atom s3r , please add
                                  kurikoK teastainT 2 Replies Last reply Reply Quote 0
                                  • kurikoK Offline
                                    kuriko @riztronic
                                    @riztronic
                                    did you mean a built-in magnetometer?
                                    • teastainT Offline
                                      teastain @riztronic
                                      @riztronic The device includes a 5V to 3.3V power circuit, a built-in three-axis BMM150 geomagnetic sensor,
                                        Calilov330000
                                        Does anyone know how to connect my m5stack core 2 ?
                                        Im using the raspberry pi 5. Is the m5stackbcore 2 plug and play with raspberry pi or the websites? Ive neen trying to connect this thing for 2 weeks. This is crazy it takes this much trouble
                                        • kurikoK Offline
                                          kuriko @Calilov330000
                                          @Calilov330000
                                          why don't you try a simple laptop/desktop?
                                            Davidalan5757
                                            Could you unlock from UIFlow 2 the capability to code in micropython…
