    195 Posts 79 Posters 569.3k Views 13 Watching
      Rango
      I'm using a MiniJoyC with M5stuckC Plus2 and UIFlow 2.1.4.
      I've read through examples and documentation but I can not get x or y values. They only display 0.
      Same thing happens in Arduino IDE.
      I do get values when using UI flow 1, so I know the minijoy is working.
      Any known issues with the UIf2 libraries?
      Thanks in advance.
      • G Offline
        gbelfor
        Using: UIFlow 2.1.5, AtomS3, KMeterISOunit
        From the version history, it appears that the Firmware changed the KMeterISOunit API a couple revs back, but UIFlow is still generating code for the old API. When I do the blockly code and run on my AtomS3, an exception is thrown showing the issue:
        Code generated (snipit)
        ...but from the latest API docs, the reading code should be:
        Note: I did a workaround using the "Execute mpy code" block and writing in the proper API calls, but it would be nicer if the versions matched up.
        • X Offline
          xs
          Are GoPlus2 module not supported in UiFlow2? Do you plan to add support?
          • X Offline
            xs @xs
            @xs Also, Servo2 module isnt sopported
            • ? Offline
              A Former User
              Hello, could you add more RTC blocks to Uiflow2? Like the ones in Uiflow1? I'm a beginner and I wanted to make a simple clock app for the cardputer but for now seems impossible for me without learning to code. Also it would be nice to have all the apps I built in the App.list section of Uiflow2 on my cardputer. Thanks! Screenshot 2024-11-17 194153.png
              cryptospokC 1 Reply Last reply Reply Quote 1
              • cryptospokC Offline
                cryptospok
                I'm using UIFlow2 on Microsoft Edge and when I try to create a variable with the name of an object that already exists, I get the conflict information and even if I correct it, when I exit the variable creation window, UIFlow2 crashes and I have to reload the page to continue.
                  cryptospok @Guest
                    riztronic
                    missing magnetometer scratch code for atom s3r , please add
                    kurikoK teastainT 2 Replies Last reply Reply Quote 0
                    • kurikoK Offline
                      kuriko @riztronic
                      @riztronic
                      did you mean a built-in magnetometer?
                      • teastainT Offline
                        teastain @riztronic
                        @riztronic The device includes a 5V to 3.3V power circuit, a built-in three-axis BMM150 geomagnetic sensor,
                          Calilov330000
                          Does anyone know how to connect my m5stack core 2 ?
                          Im using the raspberry pi 5. Is the m5stackbcore 2 plug and play with raspberry pi or the websites? Ive neen trying to connect this thing for 2 weeks. This is crazy it takes this much trouble
                          • kurikoK Offline
                            kuriko @Calilov330000
                            @Calilov330000
                            why don't you try a simple laptop/desktop?
                              Davidalan5757
                              Could you unlock from UIFlow 2 the capability to code in micropython…
                                jpilarski
                                I am looking for all of the lcd drawing tools that were available in uiflow1.0. I was making some interactive graphics and I was drawing lines or rectangles in a loop and doing that in uiflow2.0 requires you to first drag out 100 lines in the ui builder which just is too slow. Here are the bloacks I am looking for in uiflow 2.0. How can I do something similar in uiflow 2.0 Screenshot 2025-02-18 235307.png
                                  charlesRD
                                  I have some difficulties to burn UIFLOW on new devices
                                  For ATom lite it seems to work but i get ERROR The device type is unknown! on device manager.
                                  I dont know if it can acces to the wifi. i tried several time to unregister and burn it again, reinstall M5 burner, but it doesn't help.
                                  It can't connect to my M5 stamp C3, maybe there is a way to make a factory reset on them?
                                  The previous Atom and Stick set up in february still worked well, and appears with green dot on device manager. when i try to burn it now i get the "unknown type" error and red dot.
                                  it looks like i am not able anymore to have the same atom running when i burn them today.
                                  Did i forgot something ?
                                  Thank you very much,
                                  Charles
                                  • Y Offline
                                    yaleman
                                      sgu @charlesRD
                                      @charlesRD
                                      i have similar issues
                                      the Tab5 does not burn UIFlow at all!
                                        sgu
                                        When Will LVGL be integrated in UIFlow 2 ? I don't see a progress there for many months. The new devices such as Tab5 are useless without LVGL. Programming with UiFlow 2.0 and printing simple lines and squares look very old school.
                                          hacxx
                                          Thanks for sharing the UiFlow 2.0 resources! I appreciate having a dedicated space for bugs, how-tos, and feature requests. Does anyone have tips on avoiding common firmware burning errors, especially with account binding? Also curious if there’s a timeline for the full API docs release. Looking forward to seeing how this evolves!
                                            thecuri
                                            I recently los all my private cloud projects....is there a way to get them back from your servers?
