    195 Posts 79 Posters 569.0k Views 13 Watching
      Calvorotas
      I am trying to receive a bytearray via BLE from a server, but I can't get a response.
      By sending a certain bytearray via BLE to the Sbrick device, it returns a response indicating the temperature value. And through another bytearray, the voltage value is returned.
      In App Inventor I get it with these blocks:image-1.png image-2.png
      But in UiFlow 2.0 I can't get it using these blocks:
      What am I doing wrong?
      s it possible that this block will not trigger the server response?
      Perhaps, the mode argument is mode=0 (write-without-response). Or am I mixing up different things?
      I can't get a response from the server with the "When BLE client on notify" block or with the "When BLE client on read complete" block
      I need help, or a lot of help. :)
      Thank you very much.
      • greenleafG Offline
        greenleaf
        Feature request:
        Ability to set headers for Label+ objects. Many APIs required these headers before they respond with proper JSON.
        Example:
        curl -H "Accept: application/json" https://icanhazdadjoke.com/
          Rango
          I'm using a MiniJoyC with M5stuckC Plus2 and UIFlow 2.1.4.
          I've read through examples and documentation but I can not get x or y values. They only display 0.
          Same thing happens in Arduino IDE.
          I do get values when using UI flow 1, so I know the minijoy is working.
          Any known issues with the UIf2 libraries?
          Thanks in advance.
          • G Offline
            gbelfor
            Using: UIFlow 2.1.5, AtomS3, KMeterISOunit
            From the version history, it appears that the Firmware changed the KMeterISOunit API a couple revs back, but UIFlow is still generating code for the old API. When I do the blockly code and run on my AtomS3, an exception is thrown showing the issue:
            Code generated (snipit)
            ...but from the latest API docs, the reading code should be:
            Note: I did a workaround using the "Execute mpy code" block and writing in the proper API calls, but it would be nicer if the versions matched up.
            • X Offline
              xs
              Are GoPlus2 module not supported in UiFlow2? Do you plan to add support?
              • X Offline
                xs @xs
                @xs Also, Servo2 module isnt sopported
                • ? Offline
                  A Former User
                  Hello, could you add more RTC blocks to Uiflow2? Like the ones in Uiflow1? I'm a beginner and I wanted to make a simple clock app for the cardputer but for now seems impossible for me without learning to code. Also it would be nice to have all the apps I built in the App.list section of Uiflow2 on my cardputer. Thanks! Screenshot 2024-11-17 194153.png
                  cryptospokC 1 Reply Last reply Reply Quote 1
                  • cryptospokC Offline
                    cryptospok
                    I'm using UIFlow2 on Microsoft Edge and when I try to create a variable with the name of an object that already exists, I get the conflict information and even if I correct it, when I exit the variable creation window, UIFlow2 crashes and I have to reload the page to continue.
                      cryptospok @Guest
                        riztronic
                        missing magnetometer scratch code for atom s3r , please add
                        kurikoK teastainT 2 Replies Last reply Reply Quote 0
                        • kurikoK Offline
                          kuriko @riztronic
                          @riztronic
                          did you mean a built-in magnetometer?
                          • teastainT Offline
                            teastain @riztronic
                            @riztronic The device includes a 5V to 3.3V power circuit, a built-in three-axis BMM150 geomagnetic sensor,
                              Calilov330000
                              Does anyone know how to connect my m5stack core 2 ?
                              Im using the raspberry pi 5. Is the m5stackbcore 2 plug and play with raspberry pi or the websites? Ive neen trying to connect this thing for 2 weeks. This is crazy it takes this much trouble
                              • kurikoK Offline
                                kuriko @Calilov330000
                                @Calilov330000
                                why don't you try a simple laptop/desktop?
                                  Davidalan5757
                                  Could you unlock from UIFlow 2 the capability to code in micropython…
                                    jpilarski
                                    I am looking for all of the lcd drawing tools that were available in uiflow1.0. I was making some interactive graphics and I was drawing lines or rectangles in a loop and doing that in uiflow2.0 requires you to first drag out 100 lines in the ui builder which just is too slow. Here are the bloacks I am looking for in uiflow 2.0. How can I do something similar in uiflow 2.0 Screenshot 2025-02-18 235307.png
                                      charlesRD
                                      I have some difficulties to burn UIFLOW on new devices
                                      For ATom lite it seems to work but i get ERROR The device type is unknown! on device manager.
                                      I dont know if it can acces to the wifi. i tried several time to unregister and burn it again, reinstall M5 burner, but it doesn't help.
                                      It can't connect to my M5 stamp C3, maybe there is a way to make a factory reset on them?
                                      The previous Atom and Stick set up in february still worked well, and appears with green dot on device manager. when i try to burn it now i get the "unknown type" error and red dot.
                                      it looks like i am not able anymore to have the same atom running when i burn them today.
                                      Did i forgot something ?
                                      Thank you very much,
                                      Charles
                                      • Y Offline
                                        yaleman
                                          sgu @charlesRD
                                          @charlesRD
                                          i have similar issues
                                          the Tab5 does not burn UIFlow at all!
                                            sgu
                                            When Will LVGL be integrated in UIFlow 2 ? I don't see a progress there for many months. The new devices such as Tab5 are useless without LVGL. Programming with UiFlow 2.0 and printing simple lines and squares look very old school.
