    195 Posts 79 Posters 568.7k Views 13 Watching
    • ? Offline
      A Former User
      Hello, could you add more RTC blocks to Uiflow2? Like the ones in Uiflow1? I'm a beginner and I wanted to make a simple clock app for the cardputer but for now seems impossible for me without learning to code. Also it would be nice to have all the apps I built in the App.list section of Uiflow2 on my cardputer. Thanks! Screenshot 2024-11-17 194153.png
      cryptospokC 1 Reply Last reply Reply Quote 1
      • cryptospokC Offline
        cryptospok
        I'm using UIFlow2 on Microsoft Edge and when I try to create a variable with the name of an object that already exists, I get the conflict information and even if I correct it, when I exit the variable creation window, UIFlow2 crashes and I have to reload the page to continue.
          cryptospok @Guest
            riztronic
            missing magnetometer scratch code for atom s3r , please add
            kurikoK teastainT 2 Replies Last reply Reply Quote 0
            • kurikoK Offline
              kuriko @riztronic
              @riztronic
              did you mean a built-in magnetometer?
              • teastainT Offline
                teastain @riztronic
                @riztronic The device includes a 5V to 3.3V power circuit, a built-in three-axis BMM150 geomagnetic sensor,
                  Calilov330000
                  Does anyone know how to connect my m5stack core 2 ?
                  Im using the raspberry pi 5. Is the m5stackbcore 2 plug and play with raspberry pi or the websites? Ive neen trying to connect this thing for 2 weeks. This is crazy it takes this much trouble
                  • kurikoK Offline
                    kuriko @Calilov330000
                    @Calilov330000
                    why don't you try a simple laptop/desktop?
                      Davidalan5757
                      Could you unlock from UIFlow 2 the capability to code in micropython…
                        jpilarski
                        I am looking for all of the lcd drawing tools that were available in uiflow1.0. I was making some interactive graphics and I was drawing lines or rectangles in a loop and doing that in uiflow2.0 requires you to first drag out 100 lines in the ui builder which just is too slow. Here are the bloacks I am looking for in uiflow 2.0. How can I do something similar in uiflow 2.0 Screenshot 2025-02-18 235307.png
                          charlesRD
                          I have some difficulties to burn UIFLOW on new devices
                          For ATom lite it seems to work but i get ERROR The device type is unknown! on device manager.
                          I dont know if it can acces to the wifi. i tried several time to unregister and burn it again, reinstall M5 burner, but it doesn't help.
                          It can't connect to my M5 stamp C3, maybe there is a way to make a factory reset on them?
                          The previous Atom and Stick set up in february still worked well, and appears with green dot on device manager. when i try to burn it now i get the "unknown type" error and red dot.
                          it looks like i am not able anymore to have the same atom running when i burn them today.
                          Did i forgot something ?
                          Thank you very much,
                          Charles
                          • Y Offline
                            yaleman
                              sgu @charlesRD
                              @charlesRD
                              i have similar issues
                              the Tab5 does not burn UIFlow at all!
                                sgu
                                When Will LVGL be integrated in UIFlow 2 ? I don't see a progress there for many months. The new devices such as Tab5 are useless without LVGL. Programming with UiFlow 2.0 and printing simple lines and squares look very old school.
                                  hacxx
                                  Thanks for sharing the UiFlow 2.0 resources! I appreciate having a dedicated space for bugs, how-tos, and feature requests. Does anyone have tips on avoiding common firmware burning errors, especially with account binding? Also curious if there’s a timeline for the full API docs release. Looking forward to seeing how this evolves!
                                    thecuri
                                    I recently los all my private cloud projects....is there a way to get them back from your servers?
                                    • Z Offline
                                      zhumingqi
                                      I used UIFlow2 to devleop a simple UI demo, and I monitor the free memory with gc.mem_free(). I found the free memory reduced continiously though I called gc.collect() every loop. Finally, the UI can not update again, but the loop still was running.
                                      Z 1 Reply Last reply Reply Quote 0
                                      • Z Offline
                                        zhumingqi @zhumingqi
                                        I tested more UI design. And I found that the memory leak only happens when I use image component and switch images frequently. Is that a UIFlow2.3.3 bug or my design is incorrect?
                                        • Z Offline
                                          zhumingqi
                                          Today, I updated the UIFlow to V2.3.4, and burned V2.3.4 firmware as well. Then I tested that image component again with M5GFX in UIFlow 2.3.4. But the issue still exists. After I switch two JPG pics with one image component for sometime, the memory will reduced continiously. Finally, the system will break out. And I try to use gc.collect() after every drawImage(), but it's not useful.
                                          Here is my design and python code:
                                          import os, sys, io, gc
                                          import M5
                                          from M5 import *
                                          ImageSwitchFlag = None
                                          def GcCollectAndPrint():
                                          global ImageSwitchFlag
                                          gc.collect()
                                          print(gc.mem_free())
                                          pass
                                          def btnA_wasClicked_event(state):
                                          if ImageSwitchFlag == 0:
                                          M5.Lcd.drawImage("/flash/res/img/RotaryBGBacklight.jpg", 0, 0)
                                          GcCollectAndPrint()
                                          ImageSwitchFlag = 1
                                          elif ImageSwitchFlag == 1:
                                          M5.Lcd.drawImage("/flash/res/img/RotaryBGBT.jpg", 0, 0)
                                          GcCollectAndPrint()
                                          ImageSwitchFlag = 0
                                          def setup():
                                          M5.begin()
                                          Widgets.fillScreen(0x000000)
                                          BtnA.setCallback(type=BtnA.CB_TYPE.WAS_CLICKED, cb=btnA_wasClicked_event)
                                          ImageSwitchFlag = 0
                                          def loop():
                                          M5.update()
                                          if name == 'main':
                                          try:
                                          setup()
                                          while True:
                                          loop()
                                          try:
                                          print_error_msg(e)
                                          except ImportError:
                                          print("please update to latest firmware")******
                                            Schwibach
                                            I wrote in another thread about my Sync... 0% problem.
                                            I am pretty sure now that it is a bug. I does not matter which program I use. I can run them from UIFlow 2.0. But as soon as I download a program, I will get the Sync... 0%
                                            Also, if I burn firmware without selecting startup, it will not even connect to UIFlow 2.0.
                                            I would really appreciate any guidance you could give.
