UIFlow TAB5 text scaling
I had crested an application usingthe Tough, but I was asked if I could use a larger screen. The application is very simple, but part of it displays a countdown clock (mins : Secs). As the fonts supplied are quite small I had to scale the text. On the Tough (without Scaling) worked fine on the TAB5 when the time changes to 9:59 it shows 9:590 and the zero persists. Is there a way to format the clock in UIFlow so it would show 09:59?
I did a check and set scaling to 1 and the display is properly shown i.e. as 9:59 etc
