So is there any way to use external interrupts in flow.m5stack.com ? (using the micropython code)? I tried using the methods for micropython but irq is not an attribute for pin objects.
Thanks! -
@lastcaress I used the code for the button pressed, but don't know if this is accurate?
I don't understand interrupts myself but I believe that if you use the button loop instead of the system loop that that is an interrupt.
Please bare with me as I'm still documenting and exploring UIFlow. -
flow.m5stack.com, buttonA, B, C has been implemented using interrupts, or try:
from m5stack import m5button button = m5button.register(_BUTTON_PIN)
